Hello guys, A few days ago I pulled my 500KM plugs just for inspection because the engine was idling pretty rough, not extremely though, On all cylinders it looked fine but cylinder 3 where the plug had a carbon build up on top instead of white/brownish looking top, the engine is built and I've tried to put a new spark plug in yesterday with no luck engine still running rough, pretty sure it got carbon build up aswell, no fault codes at all, car drives ok but only idles rough, you can feel the vibration in the cabin and also the engine itself vibrates quite abit, RPM is steady. (I do feel sometimes that im getting engine cuts when im cruising at 100KMH at low RPMS)
I've heared it could be :
Bad injector O-RING
Bad Valves (unlikely because I've done a leakdown test a few weeks ago)
Bad/leaking Injector
have any of you encounter this problem in anyway? again I have no fault codes/ no misfires even though at idle you can hear the exhaust pops every few sec.
Engine is built (no sleeves)
JE Piston
JE Conrods
Supertech Retainers and springs
Supertech intake and exhaust valves
ANOTHER STUPID QUESTION, Could a base ECU tune for the car cause one cylinder to carbon foul the plug and not all of them?
Bad injector O-RING
JE Piston
JE Conrods
