Asahi
West Sussex
Hi all, I'll keep it brief.
Last week during this phase of bitterly cold weather my car wouldn't start. The car would start for a few seconds then stall and the glow plug light would constantly flash. I just assumed it was that and replaced all four glow plugs, some of which did measure high resistance. So after doing that and also charging up my battery to make sure. I tried to start the car multiple times today with no luck. Same running for a second then stalling.
This is the scan after I cleared all the DTC's so just the stuff that came back.
The car came with one key. A year or two ago I got a second key coded by a non-dealership company. Tried both keys and no luck with either.
I've noticed today along with the coil/glowplug light flashing the dash also says "dEF Safe"
I can post the VCDS scan prior to clearing the codes if that'll help
Any ideas with this? :frown:
Thank you :)
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E15A053662 Mileage: 347210km-215746miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC 0000SG 5934
Coding: 00002
Shop #: WSC 63251
VCID: 6A8C35B01566962BCD6-4B1E
WAUZZZ8E15A053662 AUZ6Z0D0266042
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 4529
Coding: 04255
Shop #: WSC 06435
VCID: 6596468CFC78B953E04-51CE
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 63251
VCID: 60985798E35ADC7B132-5160
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 63251
VCID: 3536D6CC0C5809D3904-4B00
1 Fault Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63251 000 00000
VCID: 3E24C9E03C6ECA8B41E-5184
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 01012
Shop #: WSC 63251
VCID: 43D2B814528CA7632E0-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00401
Shop #: WSC 00001
VCID: 3332E8D4022C17E3BE0-5184
2 Faults Found:
01177 - Engine Control Unit
65-10 - Unauthorized - Intermittent
65535 - Internal Control Module Memory Error
00-00 - -
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
Shop #: WSC 00000
VCID: 6B8230B41A9C8F23B60-5118
Address 46: Central Conv. Labels:. 8E0-959-433-MIN.clb
Part No: 8E0 959 433 BD
Component: Komfortgerát TBF 1712
Coding: 07147
Shop #: WSC 00673
VCID: 74B02BC847A250DB67A-4B00
Subsystem 1 - Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0205
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 01001
Shop #: WSC 63251
VCID: 28080FB8CBDA643B1B2-4B00
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00114
Shop #: WSC 63251
VCID: 43D2B81452BCA7632E0-5160
End----------(Elapsed Time: 05:40, VBatt start/end: 12.4V/12.4V)-----------
This came off the Auizine forum. Worth a try.
1. Disconnect battery & connect leads with a jumper wire. Wait 5-10 minutes.
2. Reconnect battery, place key in ignition & initiate reprogramming sequence.
3. Sequence = turn key to "ON" position only, wait 10 seconds. Repeat 5 times.
* Press the unlock buttons, both on the fob while in the ignition & the door button.
Held each for 5-10 seconds while key was "ON", both individually & together during each "on-off" sequence.
Don't know what sequence 's you've tried, sit in car hold the unlock button insert key into ignition still holding button, turn ignition on for a few seconds then off , remove key & release button.
Still no luck tried everything above sadly. Don't know where to start first with troubleshooting. Cheapest first approach.
Sent from my ONEPLUS A5000 using Tapatalk
