Audi A3 1.6 tdi 2011 s-tronic problem
HaloPreka
40
Novi Pazar
Hello to everyone.
I have a problem with my s-tronic gearbox on Audi A3 2011 1.6 tdi. It is a 7 speed dry clutch gearbox.
When car is not driven for few days or it stayed on cold weather out of the garage, when turning the ignition key letter displaying current speed on the instrument table is blinking. If you put the gearbox in D, it can only start with second gear, like one of the clutch can not be engaged. After car is turned on for 10 minutes and I start it again, letter indicating gear is not blinking and then I can drive normally.
Sometimes this problem is common and sometimes it does not happen, for example I drove it for 25 days without problem, but in the last 10 days problem started to show more often. One time this problem happen during driving, which never happened before.
I connected the car on VCDS and it showed this fault bellow:
If anyone had similar problem, please help, since I live in small town with not very good mechanics.
Vcds
Your metatronics are failing probably
first try a oil change.
You mean to change the oil in mechatronic? Or to change the oil in the gearbox itself?
What is the chance that computer is the problem?
