2018 Audi TTS 4 Pot Calipers
Charlie23
38
South Wales
Hi Guys,
Just purchased a set of 2018 TTS 4pots for my S3 and i need different brake lines i believe.
Does anyone have any info on this?
Update.
All fitted was all just bolt on bar the brake hoses are different. The TTS Calipers are Larger banjo fitting so hopefully Monday I will Order some TTS brake Hoses and they mate up to the S3 brake lines. (Fingers crossed)
Also need 10mm Wheel spacers as the S3 wheels catch the caliper.
The weight difference is unreal so hopefully will be a good upgrade. Discs are rusty due to fitting in the lovely welsh weather we had today :( will take better pics once all done.
Done fitted and working like a dream.
Nice easy upgrade for some 4 pot brakes.
calipers and brake hoses is all that’s required. :)
Reactions: samisnake
Ye go for it mate, good easy upgrade.
The brake hoses are on Backorder from Audi/TPS but I managed to find Borg & Beck equivalent that where available next day.
You will need a min of 9.5mm spacers also.
calipers from a 2016+ TTS
340x30mm Discs from TTS
9.5mm Spacers (40mm longer studs)
Brake Hoses (BBH8772)
Pads (PAD 2073)
Pretty sure my discs are 340 already. Trying to find some callipers is the hard part.
