Dear All,
Please help me to solve this fault, everything going fine until I have decided to change my 4 spoke steering wheel to 3 spoke steering wheel.
After that and a couple of days, on my board, this error occurred.
I have VCDS 17.1.3 and I have tried to clear these faults but they appear every time after I start the car and drive a few miles.
Also, I must note, the abs unit was replaced in the past but everything was good until last week.
Please see the log file from VCDS.
Also, I have other faults you can see exactly on my log file, if anybody can help me or suggest what I need to do I would be grateful.
LOG;
VIN: WAUZZZ8P49A0 Mileage: 168700km-104825miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 056 N HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 3039
Revision: --H09--- Serial number: AUX7Z0H8FN40MH
Coding: 0000071
Shop #: WSC 80093 222 69422
VCID: 326CC18AADB421D12F-8066
1 Fault Found:
005672 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:39:31
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00101000
Bin. Bits: 00000000
(no units): 0.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: None
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 1142401209250002881002E7901C00423800
Shop #: WSC 12345 123 12345
VCID: 76E43D9AC15C7DF1C3-8022
2 Faults Found:
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:39:31
Freeze Frame:
Count: 0
Count: 2
Count: 12288
Count: 166
Count: 43264
Count: 1
Count: 0
Count: 0
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
003 - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:39:31
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000587 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
VCID: 73E2048E122E68D9E4-8026
1 Fault Found:
01207 - Control Module for Auxiliary Heater (J364)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 237
Mileage: 155535 km
Time Indication: 0
Date: 2018.07.16
Time: 14:12:12
Freeze Frame:
ON
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002042
Shop #: WSC 00046 412 118784
VCID: 418E9E4618128A49A6-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
No fault code found.
Address 18: Aux. Heat Labels: None
Part No: 8P0 265 081 F
Component: Heizgeraet H08 0060
Revision: 00H08000 Serial number: 09011596000000
Coding: 0001012
Shop #: WSC 06314 000 00000
VCID: 3460C79257A02FE13D-8060
1 Fault Found:
02251 - Heater Unit Locked
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 237
Mileage: 155535 km
Time Indication: 0
Date: 2018.07.16
Time: 14:12:12
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K089040937
Coding: E9807F46500A022102
VCID: 3566FA965CDA36E90A-8060
2 Faults Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 14
Reset counter: 248
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:35:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 28
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:39:31
Address 37: Navigation Labels: 8J0-035-192-RNSL.lbl
Part No SW: 8P0 035 193 E HW: 8P0 035 193 E
Component: J0503 RNS-LOW 0400
Revision: 00017000 Serial number: AUZ1Z1L1111401
Coding: 0042257
2 Faults Found:
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 5
Reset counter: 248
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:35:08
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 248
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:35:08
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 232 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5CD9EA8564691197-807E
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 43
Mileage: 168695 km
Time Indication: 0
Date: 2020.09.23
Time: 18:17:07
Freeze Frame:
Voltage: 14.00 V
DU
Temperature: 34.0°C
RPM: 1766 /min
Speed: 29.0 km/h
Speed: 29.0 km/h
Count: 0
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674802823757
1 Fault Found:
02247 - Subwoofer (R148/R157)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 244
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:35:00
Freeze Frame:
Temperature: 27.0°C
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Component: Tuer-SG H03 0060
Coding: 0000252
VCID: 4480975207009F618D-8010
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
012 - Electrical Fault in Circuit
Address 56: Radio Labels: 8J0-035-192-RNSL.lbl
Coding: 0042257
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 248
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:35:08
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 248
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:35:08
LOG;
Coding: 0000071
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:39:31
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00101000
Bin. Bits: 00000000
(no units): 0.0
Revision: 00H35001
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:39:31
Freeze Frame:
Count: 0
Count: 2
Count: 12288
Count: 166
Count: 43264
Count: 1
Count: 0
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:39:31
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 237
Mileage: 155535 km
Time Indication: 0
Date: 2018.07.16
Time: 14:12:12
Freeze Frame:
ON
Coding: 0002042
Coding: 0001012
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 237
Mileage: 155535 km
Time Indication: 0
Date: 2018.07.16
Time: 14:12:12
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 248
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:35:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 28
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:39:31
Coding: 0042257
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 248
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:35:08
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 248
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:35:08
Revision: 00H15000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 43
Mileage: 168695 km
Time Indication: 0
Date: 2020.09.23
Time: 18:17:07
Freeze Frame:
Voltage: 14.00 V
DU
Temperature: 34.0°C
RPM: 1766 /min
Speed: 29.0 km/h
Speed: 29.0 km/h
Count: 0
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 244
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:35:00
Freeze Frame:
Temperature: 27.0°C
Coding: 0000252
1 Fault Found:
Coding: 0042257
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 248
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:35:08
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 248
Mileage: 168672 km
Time Indication: 0
Date: 2020.09.22
Time: 20:35:08
