Brake Bleeding
PorscheBishop
Lincolnshire
Another job looms!
Couple of questions about bleeding the brakes:
First, I have vacuum bleed tool which connects to each calliper in turn (one or two bleed nipples) and sucks fluid/air through, is this ok to use instead of the type that pressurises the system from the reservoir end? (works on a Porsche 964 C4!)
Second is this likely to throw up any error codes?
It might not work on its own..
I believe you might have to set the abs module / pump into a neutral or a bleed state for it to work with VCDS or similar.
I leave it to my specialist...
Reactions: 45bvtc
That's a very tasteful Avatar, Paul, nice; just noticed this morning :thumbs up:
Hope you and yours are well
Thanks John, I’ve only used it the last 6 years , :icon thumright: I’ll drop you a email..
T
9K
13
4K
3K
990
