Of course it is what you think what engine u have? Volkswagen..I would not use that 502/505 Says its VW compliant which is not the case
Will it really hurt? I have diesel maybe not good for petrolOld VW oil specs = poorer performance areas .
Next time will do 504 about 4months should be OK car is fine...
I freakin already did flush with semi synt. The Im not going to fkin spend 100 pouns on 3 oils..I'd change now and treat it as a flush .
Firs was mistake u can't judge me for that second emergency oil replaced next day.. It will do am no too many like others crazy like everything must be on spec.. Overreacting.. I it is just fkin car.. u won't take it to your grave don't worryNot been spending wisely...
Not betterHas anyone compared the difference in the amount of oil removed with a suction pump tube in the dip stick pipe versus removing the sump plug? It would be interesting to ACTUALLY know which is the best method for removing the most oil.
Just leave it next oil will be proper oneUmm Peter , you keep making bizarre oil choices and being pleased you bought them on Facebook market place and then claiming one up the... no harm done..
I suppose you think 502.00 505.00 will be fine in a 1.9 PD TDI ?
https://www.audi-sport.net/xf/threads/i-used-this-oil.418912/
The last one being a semi synthetic that had just an ancient and poor Mercedes Benz 229.1 manufacturer spec .
I can't understand why you can't just get the widely available, high quality universal VAG staple diet of 504.00 507.00 .
It does petrol and diesel , na and forced , PD , common rail , TFSI , 3 - 10 cylinder , RS etc , it can even be used in place of 0W20 508.00 509.00 , costs less and protects more !
All cars are different , some actually designed for it.
Best method is to extract then take the sump plug out and make a decision based on any extra amount that drips .
My two cars are fine being extracted , one has the benefit of the oil cooler being sucked out below the oil filter housing and combined with them not eating their own soot excrement the oil is never turned black .
I have ramps, but once on ramps, the car's not level - having not poked my head underneath yet (I've not had the car long), I'm not sure if that would affect draining all the oil - i.e. depends on the position of the sump plug in the sump... but it would certainly affect refilling to the correct level (before starting the engine and driving off the ramps).A decent set of ramps saves having to jack the car up. Saves a bit of hassle.
Please don't call ne Pete.. I HATE itWhat engine do you exactly have Pete ?
Was going to remove the under tray anyway
I am looking to do my own oil changes as I want to use my own oil and filters and by the time I pay for the oil and filter and ask a garage to do it for me I would be looking at well over £100.00
Do these manual oil pumps like this work: Amazon product
Or can someone recommend a cheap electric one for under £40.00 ? Sorry to hijack
Which pumps? If you have gloves there is not much mess I do it with minimum mess.. But yeah the worst part is filter change .. that's messyI dont have any jacks and cant be bothered to remove all the lower covers ect. Im lazy like that.
Have just heard good things about the pumps and a mess free oil change.
Too be honest I have never done it before so I thought it about time I start doing some of my own maintence.
I have never even touched a oil filter before so would need to do some indepth youtubing on how to do it on my car.
No not top anymore.. this isn't 8P .. 8Vs since 2013 has filters from the bottom, btw some pipes awkward to reach ...Audi (and VW, don't know about Seat) are a bit unusual. You don’t change a filter canister, you remove a cover (with a special 74mm socket, available on Amazon for less than a tenner) and inside is a paper filter element that you change. I think this can be done from the top of the engine - but do google your model, read the manual, and go look. Suction pumps are ok, in fact my C6 A6 didn’t have a sump plug at all, you had to use a pump to get the oil out.
Oh yeah isnt the oil filter in a stupid place inside the engine or like near the bottom?
I am sure I seen this in a wheelers dealers episode, but that was a TT
Oh you have TFSI that's why .. audi only messing about .. changing stuff .. making differences..The filter was accessible from the top of the engine bay on my 2015 S3. I did oil changes using the pump method and it was fine. Hardest part was disposing if the oil without getting it on the inside of the car!
