Small nail on tyre
Raul_sbd
Sale
CAB7E22E ACE9 43B1 A747 7890D9ACB2F8
Just was out and spot a small nail on my rear near side tyre.. not sure if it’s been long in it by the looks of it may be it has. Car is not apparently losing air, neither the sensors on the obc has come up. Now not sure what to do as tyre is fairly new around the 5mm left.. so would u a) repair, b) pry out the nail, c) leave it as it is, d) replace tyre (not kind on that one lol)
Thanks in advance!!
b, buy one of those repair kits first or go to somebody to do a for you
Sent from my SM-A530F using Tapatalk
I had a similar issue with a screw on a basically new tyre. I pried it out and measured it and there was no way based on the length of the screw and the remaining tread that it punctured the casing and belts.
The safe way would be to take it to a tyre dealer and let them inspect the inner casing. Nails tend to be longer than 5-7mm
Easy enough to have that repaired by any tyre place, with a bung from the inside.
I probably will call Kwik Fit tomorrow to get it done.. my gf needs the car for work (works in NHS).. any idea how much Kwik fit charges for this? Or mayb better taking it to a local tyre place?
Thanks guys
I’d call around. Kwikfit are £25. They fit a new valve and rebalance. A local garage might be a bit less.
£25 ! I was going to give it a go to the repair puncture kits they sell on eBay.. I don’t mind £10-15 but no more lol
Although seems to be free for nhs staff :) I will call them tomorrow..
Reactions: rafletcher
Judging by the bulging into the groove I'd say that is more likely to be a screw and the head has been worn away. Unless it's free for NHS at Kwikfit I'd be going to an independant.
Colin
Reactions: Neil C
25 quid is not bad....remember they have to remove, inspect for damage, repair if nescessary, replace tyre and balance the wheel
Reactions: 45bvtc
Go to a local Tyre place, they will repair for a tenner.
Reactions: RS3 S. and Damo S
All sorted now by Kwik Fit, free of charge with the gf NHS card
Reactions: 45bvtc, Fatbloke and S32B
Costco do tyre repairs for £10.
It's a repair safe area anyway no matter where you take it...I'd repair it before you come out one morning or after work to find it flat!
EDIT* Lol posted as I was doing my reply :)
Reactions: Raul_sbd
Thats the repair..probably similar to the ones that can be done with the repair kit. At least is done.. so much debri in the roads lately :(
111FDD2D E4D9 492A A6D8 28681E5931D3
Did Kwik Fit remove the tyre and repair from the inside? If they just plugged it and that looks what they did, that is not the way to do a proper puncture repair.
View attachment 204444 Just was out and spot a small nail on my rear near side tyre.. not sure if it’s been long in it by the looks of it may be it has. Car is not apparently losing air, neither the sensors on the obc has come up. Now not sure what to do as tyre is fairly new around the 5mm left.. so would u a) repair, b) pry out the nail, c) leave it as it is, d) replace tyre (not kind on that one lol)
Thanks in advance!!
B6D99D3F 581A 4BB1 9B00 5DC8F269B3EA
This is how big my was. Went into Costco to have all 4 changed on a Friday and they told me 20% off was starting on the Monday. This happened on the Sunday. I was very lucky to get away with this.
I’m not sure, they did balance and put a new valve so I believe they removed the tyre .. seems ok now :)
