I was experimenting with VCDS for the first time, and had a couple of successes, with oil temp on DIS and exhaust flaps open, but I failed to find the option to change the number of cycles the convenience turn signal makes - I wanted to try it on 5.
I’d seen this
Adaptation of the turn signal cycle - TESTED AUDI A3 1.2T â13
[09] Central Electronics -> Adaptation ->
Channel (2) Select Turn signal control convenienceturn signalflasher cycles â Set 1-5 (def=3)
but when I went to the adaptation I couldn’t find a “Channel (2)” and searching for “turn” didn’t throw up anything that looked like it.
Can this mod be done on the FL S3, and if so, how please?
I’d seen this
