RNSE upgrade to aftermarket
S3joshy
Folkestone
Hi guys, I've got an S3 2011 and am upgrading the navigation plus to an aftermarket stereo. Giving it an attempt the stereo worked but I have no sound from my speakers. After a bit of research I realised there are multiple different systems for A3/S3 but cannot find any information on how to get to work or what I need?
It's not a Bose system.
Has a quadlock and 32pin amp connector
I'm struggling to find the adapters I need? If anyone can help please?
Sounds like your amp wire isn't connected, you haven't advised which head unit you're fitting.
It's a pioneer SPH-DA230DAB.
Is this the amp wire you are on about?
Ahhhh. I have fitted this unit before, you'll need to link the amp wire from the quad lock to the head unit wire.
Are you using the connects2 can module?
I went to Halfrauds for the wiring harness, their ‘audio expert’ asks you a series of questions from drop down boxes then tells you what you need. Mine came in at £82 but I have full Bose and MFSW, not cheap but plug and play without any interference.
Finally got sound! Replaced the connects 2 leads for incartec ones, they support bose and rnse.
But steering control and back to front. Up is down and down is up
One problem after another!
