Brake disc cover plates
BigAlS3
Hello guys happy Christmas.
Not sure if this has been asked before ( can't find any information) need to change all 4 brake disc on my 2001 s3. Thought while working in that area it might be worth replacing the cover plates behind them.
My question is can they be replaced without having to remove the hubs which I don't really want to do.
Al
Al
Once the brake disc is removed from the hub you'll gain access to the 3-bolts holding the dirt shield to the bearing housing - the hub stays put
A6 backplate
See:
https://audi.7zap.com/en/rdw/audi+a3+s3+sportb+lim+qu/a3/2001-209/6/615-615016/#10
Thanks 45bvtc for your help. Would it be the same for the rears?
Yes, BigAlS3; rear brake disc off and you'll gain access to the 3-bolts holding the dirt shield to the bearing housing - the hub stays put
Excellent, thank you.
Might of seemed a basic question but just wanted to check before ordering the bits.
The rear ones can be removed but impossible to put back without removing the hub. Also get new bolts
4K
756
Aky
742
10
4K
