Audi A6 C6 2007 door issue
karollinho
EU
Hi there,
When I lock and unlock the doors with my central locking I am only able to open drivers door, all the others remain unlocked and I have to unlock them from the inside.
What could be the issue here? I doubt it's locks because all of them got broken one after another.
Auto Scan:
Tuesday,10,December,2019,18:07:18:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ4F58N007540 License Plate: MANIONAUJAS
Mileage: 249180km-154833mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 37 42 46 47 4F 52 53
55 56 61 62 69 6D 72 76 77
VIN: WAUZZZ4F58N007540 Mileage: 249180km-154833miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4F9 910 401 B HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0010
Revision: --H04--- Serial number:
Coding: 0011372
Shop #: WSC 71692 136 63941
VCID: 24475997E7DBF66FDD-8070
2 Faults Found:
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 249166 km
Time Indication: 0
Date: 2019.12.09
Time: 14:50:16
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.48 V
Duty Cycle: 15.0 %
Temperature: 10.8°C
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 249166 km
Time Indication: 0
Date: 2019.12.09
Time: 14:50:16
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.48 V
Duty Cycle: 15.0 %
Temperature: 10.8°C
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 T HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H03--- Serial number: 4330946
Coding: 0000001
Shop #: WSC 02325 758 00200
VCID: 366393DF414774FF73-8062
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0004492
VCID: 66C3039F5167C47F03-8032
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500786617
Coding: 0000131
Shop #: WSC 02323 758 00200
VCID: 63C51A8BA255B157E4-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350E 077796566
Coding: 0001001
Shop #: WSC 00000 000 08192
VCID: 25414493ECE10F67CA-8070
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000775220
Subsystem 3 - Serial number: 0131.05.070000000100011455˙
Subsystem 4 - Serial number: 011455˙
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030249321
Coding: 0002326
VCID: 1C376177DFABCEAF65-8048
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0012121
Shop #: WSC 02335 758 00200
VCID: 3169A0C3A82953C726-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046004 Serial number: AUZ5ZBG3408347
Shop #: WSC 00000 000 00000
VCID: 1A3B676FD59FB09F77-804E
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 43 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0S42YQ
Coding: 0013363
VCID: 295948A380F92B07EE-807C
Subsystem 1 - Serial number: 6332CSME19160846$
Subsystem 2 - Serial number: 6342CSME14664229$
Subsystem 3 - Serial number: 6352QSME2F233235C
Subsystem 4 - Serial number: 6362QSME3053187BG
Subsystem 5 - Serial number: 63734SME2D543561/
Subsystem 6 - Serial number: 63834SME2D7C3D2FQ
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H02000 Serial number: 90025071420530
Coding: 0002142
VCID: 275D4E9B96ED1D77F8-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 933 J
Component: KOMBIINSTR. M73 H21 0220
Revision: 00600000 Serial number: 6IN51ZU57
Coding: 3073058
Shop #: WSC 71692 136 82520
VCID: 23455A8BE2D5F157A4-8076
Address 18: Aux. Heat Labels: None
Part No SW: 4F0 910 105 A HW: 4F0 265 081 L
Component: Heizgeraet H08 0060
Revision: C Serial number: 09011480
Coding: 0000111
VCID: 1B35626BDAA5C9976C-804E
3 Faults Found:
02251 - Heater Unit Locked
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 65
Mileage: 248728 km
Time Indication: 0
Date: 2019.10.18
Time: 16:00:04
Freeze Frame:
OFF
Temperature: 80.0°C
Temperature: 84.0°C
01336 - Company Data Bus for Comfort System
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 33
Mileage: 249163 km
Time Indication: 0
Date: 2019.12.08
Time: 18:11:52
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 33
Mileage: 249163 km
Time Indication: 0
Date: 2019.12.08
Time: 19:35:25
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300807524834A
Coding: EDFE73C61B3106
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 T HW: 4E0 919 887 M
Component: MNS ECE H49 1030
Revision: 00000000 Serial number: 364E.077684645
Shop #: WSC 00477 128 57769
VCID: 3E738BFF6977BCBFAB-806A
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00-00000
Coding: 0001642
Shop #: WSC 02327 758 00200
VCID: 2C57B1B78F0B3E2F15-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H25 0200
Revision: 02000025 Serial number: 01045442750000
Coding: 3285637
VCID: 326BAFCFAD2F68DF5F-8066
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
Component: Amp.-ASK-RD H07 0270
Revision: 09S00000
Coding: 020001
Shop #: WSC 02399 823 56573
VCID: 285F4DA75BF3120FF1-807C
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000263477
Coding: 0001003
VCID: 5EB32B7F89379CBFCB-800A
1 Fault Found:
01797 - Power Steering Hydraulic Pressure Valve (N119/N315)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 6
Reset counter: 77
Mileage: 249180 km
Time Indication: 0
Date: 2019.12.10
Time: 13:52:00
Freeze Frame:
Voltage: 13.100 V
Temperature: 16.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00-00000
Coding: 0001642
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 37
Mileage: 249180 km
Time Indication: 0
Date: 2019.12.10
Time: 13:34:45
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000321
Shop #: WSC 02145 758 00200
VCID: 204F5587F3C3EA4FB9-8074
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000003
VCID: 3D718CF36471A7A7B2-8068
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394E/077775590
Coding: 0000001
Shop #: WSC 02324 758 00200
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000001993
Subsystem 1 - Part No: 4F0 915 105 E
Component: von VA0 570530U03R
Coding: 344630393135313035452056413035373035333055303352
Shop #: WSC 00000 512 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0001066
VCID: 2E53BBBFB9174C3F3B-807A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 37
Mileage: 249180 km
Time Indication: 0
Date: 2019.12.10
Time: 13:34:47
Address 69: Trailer (J345) Labels:. 4F0-907-383.clb
Part No SW: 4F0 907 383 C HW: 4F0 907 383 C
Component: Anhaenger H14 0080
Revision: 2B002001 Serial number: 00000110713034
Coding: 0100000000000000
VCID: 2B55B2AB4A0539171C-807E
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 E
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD771B74F8BFE2F55-8038
Subsystem 1 - Part No: 4F9 910 592
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD29.05.07--H21001001B0170˙
Subsystem 4 - Serial number: 1B0170˙
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0001066
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 37
Mileage: 249180 km
Time Indication: 0
Date: 2019.12.10
Time: 13:34:47
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06220715010456
Coding: 0211116
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 D HW: 4F1 862 335
Component: BTA H09 1120
Revision: 00H09000 Serial number: 00000007501978
Coding: 0050011
End-------------------------(Elapsed Time: 03:00)--------------------------
Here are the Measuring Blocks values for MVB-001 Door Status:
Thursday,12,December,2019,17:34:02:00009
www.Ross-Tech.com
Address 42: Door Elect, Driver (4F0 910 793 E)
17:33:40 Group 001: General
00000000 Door Status
00000000 Button Status
00000111 Voltages and Databus Status
11.78 V Voltage Supply
Thursday,12,December,2019,17:34:27:00009
www.Ross-Tech.com
Address 52: Door Elect, Pass. (4F0 910 793 E)
17:34:18 Group 001: General
00010000 Door Status
11.84 V Voltage Supply
Thursday,12,December,2019,17:35:15:00009
www.Ross-Tech.com
Address 62: Door, Rear Left (4F0 910 795 E)
17:35:09 Group 001: General
11.90 V Voltage Supply
Thursday,12,December,2019,17:35:40:00009
www.Ross-Tech.com
Address 72: Door, Rear Right (4F0 910 795 E)
17:35:34 Group 001: General
