Hey lads,
Wondering if anyone might be able to help. I have a 2018 FL S3 with the standard LED headlights. One of the headlights was damaged so a new control unit was bought - its the large control unit at the bottom of the headlight.
The control unit is the same part number etc. However when i fitted it, the dipped beam and main beam (flash) don't work. The fuse for the light is ok and i have swapped the control unit to the other light to prove my headlight and wiring is ok.
I have 2 codes on VCDS...
Supply voltage for LED control module - Right. Short to ground
Bulb for low beam headlight - Right. Short to ground
Im thinking the control unit i bought is faulty? Someone said they need coding in but i dont think they do?
Any ideas?
Any ideas?
