Effect said:
ess three have you driven a an S3 with teh H&Rs to compare against yours ?
Not an S3 sadly...but a TT.
Hard to judge though...
It didn't seem as keen to turn in as mine did...but that could have been down to any number of things.
Road around my way are far from good so less harshness is always a good thing.
Don't get me wrong...ARBs don't really up the harshness of the suspension. But my concern was hitting a pothole/rut on full-on cornering and having the rear uprated ARB let go, if the dampers aren't up to it.
Or, having the front struggle to find grip because the ARBs are a shade too large and they are adding to understeer.
In my view, to run a front ARB the size of the H&R, I'd want more aggressive front suspension geometry as the car won't lean as much - it wasn't leaning much on the Neuspeed/Bilstein/H&R combo as it was...but I wouldn't have wanted it to lean aly less on the roads around here - or I think I'd have been breaking traction at the front and understeering.
Personally, I prefer my 4wd cars to have some compliance, in order to make the 4wd advantage work...and to get that on an S3, I found you need some lean in order to make the front suspension geometry work for you - adding negative camber as the car leans over slightly, adding to the grip.
The problem with the standard set up is that it rolls too much...hits the bumpstop on the loaded wheel and then the 'effective spring rate' goes through the roof (like having really stiff springs/dampers fitted) and you start to understeer if you hit a small bumop etc...
Too big a front ARB has a similar effect., in my experience.
ARBs are a very emotive subject though...
And driving style can play a huge part in their selection.
also how much harsher is the ride with the ones you are using ?
My S3 was on Bilstein dampers, H&R springs, Neuspeed ARBs, Forge rear tie bars, 18" wheels and aggressive geometry...and it was not harsh at all.
Stiffer, yes. But never harsh or uncomfortable.
It's hard to say the ARBs added anything at all to the harshness...as I don't believe they did.
