Hi All,
I've recently got a rear indicator light warning in my 2013 A6 C7 Avant SE 2.0 tdi, and the rear right indicator light isn't working. This is the regular light, not a LED one.
When I disconnect and reconnect the lamp it works, but then after a few minutes of driving it stops working again.
I've tried replacing the lightbulb and even replacing the lamp, as I thought that might fix the problem, but each time it only helps for a few minutes of driving.
I thought that this might be a fuse/wire, but the other light in the same lamp works fine, no issues.
Has anyone come across something similar? Any ideas as to what could be causing it and how to fix it? Could it be the connector or the wire? If so, how to diagnose it/fix it?
Thanks very much for any help and advice
