Code Help. Is it time to cut my losses.
Nathan Russell
Isle of Wight
Website
www.albatrossandmariner.co.uk
Evening all.
Connected obdeleven to my 2004 A4 3.0tdi today just to run a routine scan. Usually 1 code on there pointing to the coolant fan module. Today though all of the following. All looks like it could be electrical, can anyone point me in any direction or does it look like gremlins have set in.
Coolant fan control module 2 Excess Temp
Code P1947
Status static
Priority 0
Frequency 254
Driving Cycle 255
Mileage 133642km
GlowPlug Cylinder 5 open circuit
Code P161e
Status Intermittent
Priority 0
Frequency 6
Driving Cycle 255
Left Rear Door Control Module
No communication
01333
Static
Right rear door control module
No communication
01334
Static
Opened due to crash signal
01366
Static
Steering column electrics control module
No communication
00466
Static
Priority 4
Frequency 6
Driving Cycle 96
Drive train data bus
Please read DTC
01312
Static
Control module incorrect vehicle identification no
Code 01794
Status Intermittent
Priority 2
Frequency 4
Driving Cycle 99
Fnt Pass side door control module
No communication
01332
Intermittent
Alarm Via Inclination sensor
00962
Static
Navigation Antenna
Open circuit
Antenna on radio
Open circuit
Connection ZF output to radio antenna amp
Open Circuit
Cd Changer
No communication / signal
You got water in anywhere or bad earth maybe checked drain plugs under battery in case it’s stood in water I had drains blocked under battery use to throw about 20 faults up on mine last year I couldn’t work it out
Good luck
Ye me neither hate electrics 1 drain under battery 1 near brake servo area if I remember right
Reactions: Nathan Russell
Have you had any battery issues such as a flat battery or had to jump start the car, You can get a lot of faults generated in this way. I would clear all the faults and see what comes back.
Checked for a water leak today. No water under the plenum cover. Also checked under drivers side and passenger side carpets. No water there either. Checked in the ecu box. Dry there too.
Any other thoughts guys?
Although I scanned it today and now only have 3 codes so it has got better!
