So, after my 150 quid A4 blew before xmas, got hold of a 05 plate A4 Cabriolet B7. When I got it, had water rather than G12/13, so kind of knew there were things going on... Found a small leak on the Rad, but liveable.
About a month back, started losing more fluid from the radiator, and it blew 2 of the hoses (to and from oil cooler). Replaced the hoses and radiator, and all seemed ok apart from a small leak when I was refilling (although this seemed to stop)
Fast forward a drive or two, and the car is dumping water when cold, but when its warmed up slightly, you can top it up and it will be fine for the day. So attention turned to the Thermostat (which i've started switching out today).
Problem is, didn't look like it is coming from thermostat but appearing at the front of the car by the aux belt..
Don't really want to tackle the water pump, but does anyone think its going to be that?
