Golf R error codes
Kenny_GTI
39
Ayrshire
anyone be able to help a friend with these error codes on his golf r.
Log posted below:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 52 55 5F A9
VIN: WVWZZZAUZEW305142 Mileage: 56807km-35298miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 B HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00322466050B2004
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TFS0205G0906259B 001003
ROD: EV_ECM20TFS0205G0906259B.rod
VCID: 2D7FC5DF7C1A0E2240-8078
6 Faults Found:
17789 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [101] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 56783 km
Date: 2019.01.09
Time: 19:11:24
Engine speed: 1025.25 /min
Normed load value: 2.7 %
Vehicle speed: 0 km/h
Coolant temperature: 65 °C
Intake air temperature: 49 °C
Ambient air pressure: 1030 mbar
Voltage terminal 30: 11.601 V
Unlearning counter according OBD: 40
Engine: operating status: IS
Engine temp. management actuator: raw value: 1586
Engine temperature management actuator: stop open: 135
Engine temperature management actuator: after-run stop: 3956
RVC_SP: 164.50 °
RVC_AV: 96.84 °
RVCPWM: -100.000 %
15462 - Control Circuit for Coolant Bypass Valve
P2681 00 [040] - Open Cricuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Mileage: 56490 km
Date: 2018.12.30
Time: 17:27:21
Engine speed: 0.00 /min
Normed load value: 0.0 %
Coolant temperature: 17 °C
Intake air temperature: 19 °C
Voltage terminal 30: 11.699 V
Engine: operating status: ES
Engine temp. management actuator: raw value: 1474
RVC_SP: 88.75 °
RVC_AV: 89.23 °
RVCPWM: 0.000 %
15470 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [237] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 56783 km
Date: 2019.01.09
Time: 19:11:26
Engine speed: 877.75 /min
Normed load value: 4.7 %
Coolant temperature: 64 °C
RVC_SP: 76.78 °
RVC_AV: 96.84 °
RVCPWM: 100.000 %
16986 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56788 km
Date: 2019.01.09
Time: 20:34:02
Engine speed: 837.00 /min
Intake air temperature: 50 °C
Voltage terminal 30: 11.718 V
Engine temp. management actuator: raw value: 1967
Engine temperature management actuator: stop open: 145
Engine temperature management actuator: after-run stop: 3948
RVC_SP: 102.50 °
RVC_AV: 122.16 °
RVCPWM: 100.000 %
16464 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56791 km
Date: 2019.01.09
Time: 20:42:03
Coolant temperature: 98 °C
Intake air temperature: 23 °C
Voltage terminal 30: 12.031 V
Engine temperature management actuator: stop open: 1967
RVC_SP: 5.75 °
RVC_AV: 131.88 °
RVCPWM: 100.000 %
16465 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56807 km
Date: 2019.01.10
Time: 18:00:23
Coolant temperature: 49 °C
Intake air temperature: 24 °C
Voltage terminal 30: 12.050 V
Engine temp. management actuator: raw value: 151
Engine temperature management actuator: stop open: 156
Engine temperature management actuator: after-run stop: 151
RVC_SP: 0.00 °
RVC_AV: 0.00 °
RVCPWM: -100.000 %
Readiness: 0000 0000
Very similar to my problem on my 2.0 TFSI engine which turned out to be the electronic thermostat that had gone faulty.
Basically the thermostats on these engines are a electrically controlled valve and what had happened to mine is it had sheared the gear off of the motor which in turn had left the valve partially open causing the same codes as your friends golf and also illuminating the engine light.
According to my TPS guy these thermostats are very common to fail as he said he sells plenty of them.
They have been revised several times as I understand and the latest one addresses the issues.
The waterpump is also in the same housing as the thermostat and is worth changing at the same time for peace of mind.
Hope this is of help to you.
Reactions: Kenny_GTI
Thank you very much for the reply dadar! Very useful and good information! I have forwarded it on to him, looks like a new pump and thermostat is required.
Cheers again!
Tying in with above this:
P2681 00 [040] - Open Circuit
Is the key fault. Open circuit on VCDS means that there’s a physical problem. Either the component isn’t working or there’s a wiring fault. In either case the the electrical circuit is somehow broken which prevents this part from working.
The rest of the faults stem from it.
4K
5K
NHN
616
