PFL Halogen to FL LED Dynamic
dannyboy1985
Runcorn
This is the way to wire your halogen pre FL to the new dynamic FL lights. You need to run 2 wires on each side from the outers to the inners. One for indicators and one for tail lamps along with one power wire for the dynamic indicator.
You will need the updated connectors for the outers and for the inners. I used model aircraft servo connectors for my inners with pre-made leads cheap and easy. You need 4 as they are 3pin each.
Note: The lamps and connectors are numbered so it’s not difficult to pair up.
Note2: After wiring lights and before coding. Lights will show fogs (dim) and brake lights (dim) brightening when selected. After coding brake and fog will be off until selected.
Credit the the other conversion threads for base info!
I will update this as I think of other bits...
Outer Lamp Left
Pin 1 – Ground Brown
Pin 2 - Tail lamp (taken from IL pin 2)
Pin 3 - Brake lamp Blue
Pin 4 - Turn signal lamp Blue/Yellow (taken to IL pin 3)
Pin 5 - live power dynamic indicator
Pin 6 – Not used
Inner Lamp Left
Pin 2 - Tail lamp Brown/Red (taken to OL pin 2)
Pin 3 - Turn signal (taken from OL pin 4)
Pin 4 - Fog lamp Red/White
Pin 5 - Reverse lamp Black/Blue
Pin 6 - live power dynamic indicator
Outer Lamp Right
Pin 3 - Brake lamp Green/Brown
Pin 4 - Turn signal lamp Mauve (taken to IL pin 3)
Pin 6 – Not used
Inner Lamp Right
Pin 2 - Tail lamp Brown/Yellow (taken to OL pin 2)
Pin 3 - Turn signal lamp (taken from OL pin 4)
Pin 4 - Fog lamp Green/Yellow
Pin 5 - Reverse lamp Green/Red
Pin 6 - live power Needed to make dynamic indicator work
Here is the coding needed. Enjoy
Deactivate left brake ⭕
Luminaire 20BR LA71-Lichtunkftion C20 from parking light generally to not active
Luminaire 20BR LA71-Lichtfunktion D20 from parking light left to not active
Luminaire 20BR LA71 light function E20 from CH / LH active to not active
Deactivate right brake ⭕
Light 21 BR RC8 light function C21 from parking light generally to inactive
Light 21 BR RC8 light function D21 from parking light right to not active
Light 21 BR RC8 light function E21 from CH / LH active to inactive
Deactivate rear fog left ⭕
Luminaire 26NSL LA72 light function E26 from parking light generally not active
Luminaire 26NSL LA72 light function F26 from CH / LH active to inactive
Deactivate rear fog right ⭕
Luminaire 27NSL RC6 light function E27 from parking light generally not active
Luminaire 27NSL RC6 light function F27 from CH / LH active to not active
Park light right ⭕
Luminaire 24SL HRA65 dimming value CD24 from 0 to 28
Luminaire 24SL HRA65 light function A24 from not active to parking light in general
Luminaire 24SL HRA65 light function C24 from not active to parking light right
Parking light left ⭕
Luminaire 23SL HLC10 dimming value CD23 from 0 to 28
Luminaire 23SL HLC10- light function A23 from not active to parking light in general
Luminaire 23SL HLC10- light function C23 from not active to parking light left
Hi, can I just check what is meant by the term live power dynamic indicator. Is this just a live that needs running to this pin?
also does anyone have any links to the clips I’ll need?
thanks
Conor
Yes, just 12v power. I used 3 pin Rc connectors for the inners but you probably need the correct connectors for outers as it is outside.
Sorry me again I’ve been sent these of the lights would I just be able to crimp into these using the wiring above?
thanks
Hi, thanks so much for your guide! I’ve wired in the lights now and I’m not getting a reverse or fog? Is this because I’ve only tried on 1 side?
cheers
