Hi guys, with the temperature drops, I happened to occur the following problem. If the temperature is lower than 5 degrees, the car will not start properly. If the start is successful, for about 20-30 seconds, when you press the gas pedal, nothing happens. RPMs stay at like 600-700 and slowly go up to 1000 and once its at 1000, you can press the gas pedal and the car would function normally. I've uploaded a video of the problem, you can see the rpms at like 700 and slowly going up. I've changed the filters, also one of the glow plugs, it was faulty.
