Good Gauges
What are you using?
  • Reacetech
    Votes: 0 0.0%
  • Mocal
    Votes: 0 0.0%
  • VDO
    Votes: 0 0.0%
  • TIM
    Votes: 0 0.0%
  • SPA
    Votes: 0 0.0%
  • Smith
    Votes: 0 0.0%
  • Total voters
Pyeman
Member
I'm looking at boost, oil pressure/temp gauges.
I wanting 1's that work properly and that don't lie like your cheap eBay rubbish.
I'm thinking Stack, Racetech or Mocal.
Manual or electric??
What's people options??
You can spend a lot of money on gauges and you aren't looking at them very much. I decided to go for a cheaper Ebay item. I am pleased with it, works well and is accurate. Only issue with it is that the battery voltage display is orange and isn't really visible in the day. Not where I have the gauge anyway. If it was lower in the car in the centre probably be OK. But the battery gauge bit was an extra that I wasn't that fussed about.
Works well on the track so I can check the oil temp and pressure readings.
https://www.audi-sport.net/xf/threa...ar-g25-660-upgrade.319422/page-2#post-3064892
https://www.ebay.co.uk/itm/DEPO-Rac...nd-oil-temperature-gauge-4-in-1/362104220213?
I have added an extra sensor to measure fuel pressure and have a switch on the dash so I can switch between fuel and oil pressure.
https://www.ebay.co.uk/itm/1-8-NPT-...er-Sensor-Oil-Fuel-Air-Water-UK/283036015774?
dsc_2703-jpg.132960
Reactions: andrew_wright
530
559
555
856
759
