Prokit786
Hi there! I have a problem with my Audi A4 3.0 TDI B7 ASB engine code. It doesn't want to start. I suspected that the pump in a tank was not working and when I removed the the main supply from the fuel filter to check it. I turned the ignition on there was no fuel coming out. When I cranked it then it started pumping. I fitted it back and started it but no sign of firing. I used quick start spray it started and cut off. I sprayed it continuously while cranking and it keeps on idling and cuts off after the spray was finished.
Anyone with an idea about what could be the fault.
Here are some reading from the diagnostic machine
