Airbag Light Help
8h3tdi
Decided to sort out my airbag light now the mot is coming up.
I wondering if anyone had any experience in this fault code?
Do i need a new module or is some wiring some where playing havoc with it?
Address 15: Airbags Labels: 8H0-959-655-94.lbl
Control Module Part Number: 8H0 959 655 E HW: 8H0 959 655 E
Component and/or Version: Airbag 9.42 H09 1840
Software Coding: 0071114
Work Shop Code: WSC 00672 785 00200
VCID: 3C775E967FAA8DA2BC-8068
1 Fault Found:
00003 - Control Module
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Address 15: Airbags (8H0 959 655 E)
17:00:08
Correct Airbag (Stage 1) Driver Side
Correct Airbag (Stage 1) Passenger Side
Correct Belt Tensioner Front Driver Side
Correct Belt Tensioner Front Pass. Side
Correct Belt Tensioner Rear Driver Side
Correct Belt Tensioner Rear Pass. Side
Not Installed Belt Tensioner Rear Center
Correct Pyrotechnic Igniter Battery Separating
Correct Voltage Supply
Not Installed Occupied Seat Sensor Pass. Side
Belt: Yes Belt Inquiry Front Driver Side
Not Installed Belt Inquiry Front Pass. Side
17:01:05
Belt: No Belt Inquiry Rear Driver Side
Belt: No Belt Inquiry Rear Pass. Side
Correct Side Airbag Front Driver Side
Correct Side Airbag Front Pass. Side
Not Installed Side Airbag Rear Driver Side
Correct Side Airbag Rear Pass. Side
ON Passenger Airbag Status
ON Key Switch Logic Contact 1
ON Key Switch Logic Contact 2
Correct Airbag (Stage 2) Front Driver Side
Correct Airbag (Stage 2) Front Pass. Side
Correct Knee Airbag Driver Side
17:02:01
Correct Knee Airbag Passenger Side
Correct Roll-Over Bar Driver Side
Correct Roll-Over Bar Pass. Side
1.0 Roll-Over Bar Trigger Counter
00000 Work Shop Code Counter Reset
3.4 Airbag (Stage 1) Driver Side
2.6 Airbag (Stage 1) Passenger Side
2.6 Belt Tensioner Driver Side
2.6 Belt Tensioner Passenger Side
Too High Belt Tensioner Rear Left
Too High Belt Tensioner Rear Right
no Value Belt Tensioner Rear Center
17:02:40
Too High Pyrotechnic Igniter Battery Separating
2.8 Side Airbag Driver Side
3.0 Side Airbag Passenger Side
no Value Side Airbag Rear Left
Too High Side Airbag Rear Right
3.3 Airbag (Stage 2) Driver Side
Too High Airbag (Stage 2) Passenger Side
Too High Knee Airbag Driver's Side
Too High Knee Airbag Passenger Side
4.4 Roll-Over Bar Driver Side
4.3 Roll-Over Bar Pass. Side
I'm not 100% sure but in my experience airbag lights coming on is usually the airbag connection under one of the front seats. I think it's usually the yellow connector.
Hope that helps
911
NHN
638
NHN
982
