Tesco's best!What car are we talking about? PFL RS3?
What fuel is in the car? What is the official Audi 0-62 time? 4.3?
Not sure. Mine was stage 1 but I never timed it. It felt significantly faster, though. That said, the big improvements in time would come beyond 60mph.
Custom tune from MRC. It was hugely faster than stock.Were you running a custom map, or tuning box?
Your power figures are not correct or you are reading the chart wrong. You will not be making peak power at 2600rpm.
Peak power should be made at 5k+, preferably 6k+ so you can use the full rev range. Are you reading the power and torque lines the wrong way round?
That's what I thought! the fuel is low now so I'll see if my mates free with the dragy.At first glance it looks spot on. Not sure why you're not getting into the 3's to 60mph.
Yes, nothing wrong with that chart.
https://www.mlperformance.co.uk/products/dragy
Instead of wasting money on dyno’s, buy yourself a Dragy, half a tank, on your own on a quiet stretch of private runway and do a 0-100mph pull. If 60 is under or around 4secs and 100 is between 9-10secs then you have the power you should.
Having came from a MK7 Golf R dsg so basically the same as S3 this is what I found.
Both cars standard RS3 is night and day quicker.
Golf R Apr stage 1 very similar performance to pfl RS3 standard until very high speed
Golf Apr stage 2 much quicker than standard RS3.
So unless the S3 is modified you should be wiping the floor with it.
But does sound like you have a problem, has the car had it’s spark plugs changed ?
Should be done every 19k
They do tend to make a bit of a hiss when on full boost cause the dv opens to regulate the boost pressure which is the noise you hear.
I done a little video of mine last week and you can hear that as the revs increase you can hear the turbo more.
Best dry tyre I’ve used was the yoko ad08r semi slicks and Iv just swapped over to good year f1 for the winter and wet or dry I fine them brilliant and better then the PS4’s I hadIve only done a few runs to 60 so far in the 2 weeks ive had my 16 plate. In the wet the p zero dont seem to grip on launch like the ps4 on my s3 did, but managed a verified 4.3 and an unverified 4.1 (dragy) more testing needed
Coming also from a Golf R, I wouldn't say the difference to the RS3 in speed is night and day, my father drove my RS3 the other day and even commented that he felt the Golf R was faster (he didn't go above 4000 rpm in the RS3) and that the RS3 was bit lazy, which it is at low rpm. The RS3 is faster but not night and day. My Golf R was stock and was very fast, would hit 170 mph like it was nothing. The main difference and buying argument for me is the noise.
Interesting, I don't hear this hiss on my car at all. In you car is very noticeable.
Iv had the fl S3 and pfl rs3 and after 80 mph I think it is night and day and I imagine the go model is again another levelI hit 170 on my 2016 Golf R several times.
For example in a straight where I would hit 153 on the Golf R I hit around 160 on the RS3, it is not night and day difference.
I have no doubt that the RS3 is the clear winner in a straight line, but it is not a HUGE difference as people may think.
