Problem screen MMI + Multimedia MMI Audi S3 8V
pronati
israel
Hello.
My car is AUDI S3 8V 2014.
I want to upgrade my MMI screen to 7 inches
As well as the HARMAN multimedia system
I bought the parts (new) unused
https://www.ebay.com/itm/NEU-OEM-Au...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
and
https://www.ebay.com/itm/Navigation...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
I connect all the connectors of both screen and multimedia 100% Right
Then, I see the screen in black.
I do not have a display on the screen
At the moment it is always in an "open"
And I can not close and open the screen with the button
If I connect my previous multimedia system (not HARMAN) and with the new 7 inch screen
I also see a black screen, but I do manage to close and open the screen with the button.
The HARMAN multimedia system seems to work after I connect it and its lights are also on.
Please help with the solution ??
Hello.
and
Sorry but this is not a plug and play with the new mmi. There is alot of work involved such as component removal, vcds and other misc.
First question is how do you know the parts you purchase is fully working?
Sent from my ZTE A2017G using Tapatalk
The parts are 100% new. (unused)
The screen seems to work, but it does not open and closes with the button.
Only if I turn on a switch is it opened or switched off and it closes
I do not see a screen display, black screen.
The multimedia system also seems to be working, and the lights are on.
Is there a guide how can I do at least see a "monitor" on the screen?
updating.
I now return to the original screen + Multimedia (Previous)
I still see a black screen !!
Tips What to check?
updating.
Tips What to check?
Sounds like you may have damaged a connector / wire while trying to swap over your parts. I would start by checking all the physicals.
Re your retrofit / upgrade, forget it. You will need component protection removing and feature relicensing in order for Bluetooth and Navigation to work. Expect an approx cost of £900.00 to get the 7" tech pack system working.
VCDS CODE
2 Faults Found:
1555 - Check Software Version Management
B201A 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 122571 km
Date: 2018.03.16
Time: 01:33:39
Voltage terminal 30: 12.3 V
6660 - No Communications with Display Unit 1 for Multimedia
U10E2 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 122571 km
Date: 2018.03.16
Time: 01:33:41
Voltage terminal 30: 12.2 V
Can anyone tune me in which wire / connector should I check to be responsible for the broadcast display?
bluetooth works, working speakers. System works 100%.
Only I do not see an on-screen display (previous screen and multimedia)
I would be happy if someone could help me what to do
Code:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 52 55 5F A9
VIN: WAUZZZ8V4EA107522   Mileage: 122948km-76396miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CJXB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259     HW: 06K 907 425 A
   Component: 2.0l R4 TFSI  H09 0006
   Revision: --H09---
   Coding: 0A1D00122426010B3000
   Shop #: WSC 12345 123 45678
   ASAM Dataset: EV_ECM20TFS0218V0906259 001008
   ROD: EV_ECM20TFS0218V0906259.rod
   VCID: 7DB213F4EC35FCAEFA-8028
No fault code found.
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 011 R    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4319
   Revision: 05852204    Serial number: TFK01311043143
   Coding: 0014
   Shop #: WSC 04742 780 00200
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 240406902F1F6D66D5-8070
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
          P1734 00 [002] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 AA    HW: 5Q0 907 379 G
   Component: ESC           H31 0457
   Revision: 00000000    Serial number: 631630000007E0
   Coding: 30F16BA254202A73037C070241C5690CD62A54C0E08296F7024100788605
   Shop #: WSC 32680 002 104857
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
   ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
   VCID: 7BB61DECF221F29EC4-802E
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 5Q0 959 435 A    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0604
   Revision: 00021000    Serial number: 0194839448
   Coding: 030C0C
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_KessyHellaMQBAB 002011
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A38D8E8BD9B0B969F-806E
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-043.clb
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000195602
   Coding: 00000014010000011000000000001500
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
   ROD: EV_AirCondiFrontVaAU37X.rod
   VCID: 3228F0C865EBF3D657-8066
   Relative humidity sensor in fresh air intake duct:
   Subsystem 1 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0003
   Serial number: 7D584BD6000000000001
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011332000347
   Coding: 04151A42C20122F543044004001C07A80800000000000000000000000000
   Shop #: WSC 65062 001 1048576
   ASAM Dataset: EV_BCMCONTI 012001
   ROD: EV_BCMBOSCH_012.rod
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 131020  041 0580
   Serial number:         131021145705
   Coding: 0A47F7
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0004
   Serial number: 62927051
   Coding: 02006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 K    HW: 8V0 941 531 K
   Component: E1 - LDS MQB  H05 0032
   Serial number: 13 09 2013  00000561
   Sun Roof:
   Subsystem 4 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO25276501
   Coding: 901E00
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R042V38
   Coding: 98CCC000000000005C5400CA004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 4BD68D2CE201821E34-801E
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 480 001 811 13
   Component: SideSensor_Df  001 0887
   Serial number: 35767000000D820D3E0
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 480 001 811 13
   Component: SideSensor_Pf  001 0887
   Serial number: 358670000008520D3E0V
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 480 401 911 13
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502A31118A30F28+
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 480 401 911 13
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502A31118A35D22$
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 480 400 410 13
   Component: FrontSensor_D  001 6149
   Serial number: 35565029D1171FE3407F
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 8V0 953 521 CF    HW: 5Q0 953 549 C
   Component: Lenks. Modul  002 0110
   Revision: --------    Serial number: 14111304401494
   Coding: A418
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 004C6A009BC7914691-8054
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 8V0 920 870 N    HW: 8V0 920 870 N
   Component: KOMBI         H03 2220
   Coding: 07AD001A2B8000080101A800100000
   Shop #: WSC 32680 002 1048576
   ASAM Dataset: EV_DashBoardVDDMQBAB 008031
   ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
   VCID: 46C0BC18F9637F76EB-8012
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001280053
   Coding: 030100042F085A005B0002681C0B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3FCEA9FCA6B92EBEA8-806A
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Component: E221 - MFL  H02 0014
   Serial number: 04 11 2013  D0344260
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 5018051803
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 H    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7083
   Serial number: HA1-00007.02.17
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004_VW48.rod
   VCID: 4AD88828ED7B9B160F-801E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5Q0-905-861.clb
   Part No SW: 5Q0 905 861 A    HW: 5Q0 905 861 A
   Component: ELV-MQBA      H01 0120
   Revision: 00000000    Serial number: 13000263275001
   Coding: 5D00000000000000
   ASAM Dataset: EV_ELVMarquMQB 004111
   ROD: EV_ELVMarquMQB_004_VW37.rod
   VCID: 3424F6D09FFFFDE645-8060
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 B    HW: 5Q0 959 593 B
   Component: TSG FS        020 0025
   Serial number: 12111306070188
   Coding: 001C1E205C00040100001002
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
   VCID: 40CCAA00DB475146D1-8014
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3522CBD49485E4EE72-8060
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 B    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0025
   Serial number: 13111302091485
   Coding: 001C16205E00040100001002
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
Address 55: Headlight Range (J431)       Labels:| 5Q0-907-357.clb
   Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
   Component: LWR-ECU       005 0080
   Revision: --------    Serial number: --------------
   Coding: 01AA000001000000
   ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75A20BD4D405A4EEB2-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
   Component: MU-S--ER      040 0420
   Serial number: A3E02311131519
   Coding: 01730000FF00000011110001000A00002F0002040100010002
   Shop #: WSC 54321 444 54321
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_AU37.rod
   Multimedia Operating Unit:
   Subsystem 1 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Component: ControlUnit_B  H41 0054
   Serial number: ALJAL119051600020043
2 Faults Found:
          B201A 00 [009] -  -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 235
                    Mileage: 122948 km
                    Date: 2018.03.19
                    Time: 04:44:30
                    Voltage terminal 30: 12.1 V
          U10E2 00 [009] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 235
                    Mileage: 122948 km
                    Date: 2018.03.19
                    Time: 04:44:33
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0008
   Serial number: 131029200073
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
End----------(Elapsed Time: 01:20, VBatt start/end: 12.3V/12.3V)-----------
I will be happy if someone can help me.
I do not want to pay $ 250 just for an AUDI garage test that's very expensive!
Code:
   Revision: --H09---
   Coding: 0014
1 Fault Found:
          P1734 00 [002] - -
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 02006C
   Light switch:
   Sun Roof:
   Coding: 901E00
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: A418
   Alternator:
   Coding: 0001
   Coding: 8103
2 Faults Found:
          B201A 00 [009] -  -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 235
                    Mileage: 122948 km
                    Date: 2018.03.19
                    Time: 04:44:30
          U10E2 00 [009] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 235
                    Mileage: 122948 km
                    Date: 2018.03.19
                    Time: 04:44:33
You mwould seed the VCDS header information.
What does that mean ?
Monday,19,March,2018,15:55:36:50322
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.1.0 (x64) HEX-NET CB: 0.4401.4
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: WAUZZZ8V4EA107522 License Plate:
Mileage: 122948km-76396mi Repair Order:
That?
www.Ross-Tech.com
That?
You should update your VCDS.
Code:
Monday,19,March,2018,16:24:38:50322
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
Data version: 20180212 DS287.0
www.Ross-Tech.com
   Revision: --H09---
   VCID: 7DB213F4EC35FCAC73-8028
   Coding: 0014
   ROD: EV_TCMDQ250021.rod
   VCID: 240406902F1F6D645C-8070
   ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
   VCID: 7BB61DECF221F29C4D-802E
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002.rod
   VCID: 3A38D8E8BD9B0B9416-806E
   VCID: 3228F0C865EBF3D4DE-8066
   Coding: 0A47F7
   Coding: 02006C
   Light switch:
   Sun Roof:
   Coding: 901E00
   VCID: 4BD68D2CE201821CBD-801E
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: A418
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 004C6A009BC7914418-8054
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   VCID: 46C0BC18F9637F7462-8012
   ROD: EV_GatewLear_010_VW37.rod
   VCID: 3FCEA9FCA6B92EBC21-806A
   Alternator:
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_004.rod
   VCID: 4AD88828ED7B9B1486-801E
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424F6D09FFFFDE4CC-8060
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 40CCAA00DB47514458-8014
   Coding: 8103
   VCID: 3522CBD49485E4ECFB-8060
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   ROD: EV_HeadlRegulVWLWRMQB.rod
   VCID: 75A20BD4D405A4EC3B-8020
   ROD: EV_MUStd4CPASE_VW37.rod
2 Faults Found:
          B201A 00 [009] -  -
          [Check software version management]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 235
                    Mileage: 122948 km
                    Date: 2018.03.19
                    Time: 04:44:30
          U10E2 00 [009] - -
          [Display 1: no signal/communication]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 235
                    Mileage: 122948 km
                    Date: 2018.03.19
                    Time: 04:44:33
Cannot be reached
End-----(Elapsed Time: 01:40, VBatt start/end: 12.2V/0.0V. VIgn 0.0V)------
Code:
www.Ross-Tech.com
   Revision: --H09---
   Coding: 0014
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 02006C
   Light switch:
   Sun Roof:
   Coding: 901E00
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: A418
   Alternator:
   Coding: 0001
   Coding: 8103
2 Faults Found:
          B201A 00 [009] -  -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 235
                    Mileage: 122948 km
                    Date: 2018.03.19
                    Time: 04:44:30
          U10E2 00 [009] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 235
                    Mileage: 122948 km
                    Date: 2018.03.19
                    Time: 04:44:33
Cannot be reached
You have one of the following issues:
1) Your display unit is faulty, or has a faulty component.
2) the cable which connects to your display unit is faulty.
3) display unit has no power.
1 - 100% display unit works, I try another screen and also I see a black screen.
2 -
Which cable is a video?
I have 3 connections.
White cable, black Connector (electricity) and the black connector with connecting wires Yellow (Flat)
3-
The display unit has power, the screen goes up and down when I START the vehicle, and the button works and the screen goes up and down
2 -
3-
This would suggest that you have a faulty video cable or a possible faulty 5F unit then, the video card. Video should be the four pin connector on the rear of the screen.
Red or green or black ?
ctxczc
https://ibb.co/ctxczc
The four pin round connector (RED).
I will buy a display cable and attempt to replace the cable to see if the problem has been resolved.
But I'm having some trouble to find the part number.
I have seen on the cable has the part number: 4E2035750A
I searched Google and everywhere and did not find that part.
I found only 1 person in EBAY who sells the part (used) but with part number 4E2035750 (without A)
Can anyone help me find the part or number of another part that needs to work for my screen?
Hi,
Did you solve this issue? Because I have exactly same problem.
13
