Is it just me or does anyone elses start/stop system stop too early? When I pull up to a junction I find it stopping before Ive actually stopped, which in turn makes steering impossible.
Interestingly my A3/S3 were both PFL.I believe it's a feature of the FL in that it's designed to cut off just before it actually stops.
My PFL won't until it's actually stopped, but then it hardly ever works anyway!
I'm surprised how quickly mine starts to work actually, I can drive a couple of minutes from home in the morning and it will cut out. If it was colder then it wouldn't though I guess, everything needs to get a bit warm I thought.... - climate control is always set to 20c for what its worth.
It's too eager to stopYes it is by design and if you turn the steering wheel the car will restart. Can't see what the issue is with it really...
That’s a lie. I had an 8v S3 prior and it worked as it should.
I know. But they're not lying as it is operating as it should, despite the fact the vast majority of us hate it.I mean Audi are lying lol
Only if you don't understand how the system works. A quick gentle touch on the throttle starts the engine, or put the gearbox into sport. Never once have I been left with a dead engine with the same system on my A4..If you are on a busy road about to turn right against traffic (in the uk) and you slow to near stop and then a gap opens.. you can be left stranded in the road pulling on the wheel to get it to turn again
Sent from my iPhone using Tapatalk Pro
Which is all well and good for those of us how know how to use the car, I recon at least 50% don't know why/how/when you should put the gearbox into sport or manual.Only if you don't understand how the system works. A quick gentle touch on the throttle starts the engine, or put the gearbox into sport. Never once have I been left with a dead engine with the same system on my A4..
It did it on my car yesterday, we were visiting a grave and on the way out I slowed down at a crossroads to turn left and it cut out for a split second until I touched the accelerator again! Hence why I normally turn the thing off, as it's a pain at times.I still don't think it should cut the engine before you have stopped anyway.
Seeing a lot of hate for start-stop, do most of you guys drive s-tronics? I always think it works pretty well on a manual, as I can regulate when I want it to cut out or not just by keeping the clutch down.
As someone said above, it's a terrible feature if you're waiting to turn right or about to pull out at a roundabout, but its perfectly acceptable when you're a long way back from the front at a set of lights.
