Saloon OBDeleven Help
thedru13
West Chester PA
So I think I made a booboo.. I was in obdeleven and hit the wrong thing and now I have an error I can't clear. I activated lane assist by accident and I don't have that option now I get "Audi Side Assist malfunction please contact service" . I thought I undid all the changes but can't clear the code. Can anyone help me out or did I do something that can't be undone?
Double check you turned that setting off and didn't turn anything else on and then just leave the car.
Sometimes just letting it have time will fix the issue - perfect example is the if you change the dials they do not appear right away.
Thanks. Gave it a few days and still not resolve. Took it to the dealer today they need to reflash everything to get it back to normal. Figured I was doing more damage then good the more I kept messing around with it. Hopefully the reflash works.
Is there a charge for that? We’re they unhappy you were messing with the car software?
They didn't charge me but Just got home and car threw the code again and a new one. So not sure how I am going to untangle this mess. Seems like the car is still thinking it has the lane assist but it doesn't. All the things in lane change assist 3C are turned off yet it still is throwing the code. No clue how I messed things up this bad. Now I get a new error that the Rear parking aid: obstacle detection restricted...
Here is a VagCom Log
Chassis Type FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 47 52 5F
6C BB BC
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (------DAZA) Labels: None
Part No SW: 8V0 907 404 G HW: 07K 907 309 E
Component: 2.5l R5/4V TF H22 0002
Revision: 53H22000
Coding: 0A250032242600053620
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM25TFS0118V0907404G 001002
ROD: EV_ECM25TFS0118V0907404G.rod
VCID: 3D7AE86DAC1C72AEA1-8068
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0DL 300 012 H HW: 0GC 927 711 G
Component: GSG DQ500 H06 2112
Revision: 00H06V07
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 2E58DF21717A993628-807A
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8V0 614 517 C HW: 8V0 614 517 C
Component: ESC H25 0621
Revision: 00000000 Serial number: 61897000000824
Coding: 2EAA6B7DD4990BAA89970B6681966974D62BD091D0819636024150D4828812
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
ROD: EV_Brake1UDSContiMK100IPB_035_AU37.rod
VCID: 3972FC7DB8344E8E8D-806C
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0448153803
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3C7CE569B7067BA696-8068
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0130
Revision: 20002000 Serial number: 00000001297266
Coding: 03000015010000000000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 40849199DBEE1F46CA-8014
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 4C00D8B800PAG0MUFU03
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H36 0253
Serial number: 01001721200247
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 06084781B94AF176B0-8052
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 170608 043 0585
Serial number: 170628031212
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 62938507
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 18 03 2017 00002218
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000070231710
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST001P0PAP00000
Coding: 101F00
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Component: PDC 8 KanalH07 0044
Serial number: 000308418617194
Coding: 0470151011
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_EPHVA18AU3700000 009035
ROD: EV_EPHVA18AU3700000.rod
VCID: 4B9EB6B5E2A8CC1E2F-801E
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 G HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0082
Serial number: 100517004
ASAM Dataset: EV_AudiMagneRide 002008
ROD: EV_AudiMagneRide_002_AU37.rod
VCID: 458A808DC4CC3A6EF9-8010
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR08HMAT
Coding: 9DFCFCC0008000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 47968A85FEC0287E0B-8012
Belt Pretensioner left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H37 0350
Serial number: 34258931A11071740072
Coding: 333135
Belt Pretensioner right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H37 0350
Serial number: 34258932A12071750003
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 694000000000001MP2XG
Coding: 303337
Side Sensor Driver Front:
Subsystem 4 - Part No SW: ----------- HW: 480 000 308 17
Component: SideSensor_Df 001 0887
Serial number: 35700000000F0988172M
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 5 - Part No SW: ----------- HW: 480 000 308 17
Component: SideSensor_Pf 001 0887
Serial number: 35800000000EF888172-
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 6 - Part No SW: ----------- HW: 480 400 307 17
Component: SideSensor_Dr 000 6149
Serial number: 35100019D2600D5525D/
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 7 - Part No SW: ----------- HW: 480 400 407 17
Component: SideSensor_Pr 000 6149
Serial number: 3520001A125F5886B499
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 402 306 17
Component: FrontSensor_D 001 6149
Serial number: 35500029B24F3854A112
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 402 306 17
Component: FrontSensor_P 001 6149
Serial number: 35600029B24F3855F119
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 KK HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 17071704400386
Coding: 2018
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_020_AU37.rod
VCID: 0D1A78ADDC3C822EF1-8058
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 8V0 920 890 A HW: 8V0 920 890 A
Component: FBenUSA H16 0066
Coding: 086D18533B88CF050204EC041800001000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001027
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3B7EE675B2087C9E9F-806E
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 27061710803012
Coding: 03010004340860005B00802EB80B00000001010000000000000000000000
ASAM Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW27.rod
VCID: 336ECE559A58B4DE47-8066
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170726152456 22093
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H10 9070
Serial number: 9960034404
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00009.06.17
Coding: 0601
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
VCID: 4D9AB8AD1CBCC22E31-8018
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000203468008
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 346CCD499F56B3E65E-8060
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 3Q0 907 566 F HW: 3Q0 907 566
Component: MRR1Rear H21 0610
Revision: --------
Coding: 040002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001007
ROD: EV_RearRadarS1BoschVW48X.rod
2 Faults Found:
729349 - Control Module for Lane Change Assistance
C1114 54 [009] - Missing Calibration / Basic Setting
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 80
Mileage: 3424 km
Date: 2017.11.19
Time: 18:32:15
Control Module temperature: 33 ∞C
Voltage terminal 30: Measured value not available
Vehicle speed: 0.00 km/h
Terminal 15 status: Measured value not available
Voltage terminal 15: 11.80 V
729605 - Control Module 2 for Lane Change Assistance
C1115 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 80
Mileage: 3424 km
Date: 2017.11.19
Time: 18:32:15
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 240517EEO19082
Coding: 005D1B205C00048000000002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
VCID: 438E9E95CAF8045ED7-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8106
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 3A70E371BD32459684-806E
Address 47: Sound System (J525) Labels:* None
Part No SW: 81A 035 466 B HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0440
Revision: 00000001 Serial number: AUZ8ZAH5F00MJ1Z
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 244C3D092FB62366CE-8070
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 300617EFT39127
Coding: 005D13205E00048000000002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
VCID: 42809B91D5E20D56DC-8016
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 8V1 035 880 B HW: 8V1 035 880
Component: MU-P-LNS-US 054 1110
Serial number: A702H0H2502424
Coding: 017361020000000011220002041A00102F0028E5017001047E
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU37.rod
Data medium:
Subsystem 1 - Part No SW: V03 959 801 GH HW: -----------
Component: NAR 2017/2018 --- 0060
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9H1Y04NFT
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL125051700050683
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 3012
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0273010102002001400040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 200617EFK03358
Coding: 000C13204000048000000002
ASAM Dataset: EV_DCURearDriveMINKLO 006003
ROD: EV_DCURearDriveMAXCONT_VW37.rod
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 200617EFK03351
ASAM Dataset: EV_DCURearPasseMINKLO 006003
ROD: EV_DCURearPasseMAXCONT_VW37.rod
End-------------------------(Elapsed Time: 07:27)--------------------------
Address 3C: DTCs cleared
Address 3C,3Q0 907 566 F,recoded (Long Coding),from,040002,to,04C002,(12345/123/61029),
6C BB BC
Revision: 53H22000
Revision: 00H06V07
Coding: 0014
Coding: 030C0C
Coding: 0A47F7
Coding: 00006C
Light switch:
Alarm horn:
Sun Roof:
Coding: 101F00
Coding: 0470151011
Coding: 333135
Coding: 333135
Occupant Detection:
Coding: 303337
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2018
Alternator:
Coding: 0601
Revision: --------
Coding: 040002
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 80
Mileage: 3424 km
Date: 2017.11.19
Time: 18:32:15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 80
Mileage: 3424 km
Date: 2017.11.19
Time: 18:32:15
Coding: 8106
Data medium:
Any chance you can post the VCDS header data for this scan?
Sorry about that. Just ran a new scan here are the results.
Monday,20,November,2017,16:48:50:28124
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: License Plate:
6C BB BC
VIN: Mileage: 3498km-2173miles
Revision: 53H22000
Readiness: 1110 0101
Revision: 00H06V07
Coding: 0014
Coding: 030C0C
Coding: 0A47F7
Coding: 00006C
Light switch:
Alarm horn:
Sun Roof:
Coding: 101F00
Coding: 0470151011
Coding: 333135
Coding: 333135
Occupant Detection:
Coding: 303337
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2018
Alternator:
Coding: 0601
Revision: --------
Coding: 04C002
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 84
Mileage: 3498 km
Date: 2017.11.20
Time: 16:35:50
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 84
Mileage: 3498 km
Date: 2017.11.20
Time: 16:35:50
1192264 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 84
Mileage: 3498 km
Date: 2017.11.20
Time: 16:35:50
Coding: 8106
Data medium:
End-------------------------(Elapsed Time: 06:10)--------------------------
www.Ross-Tech.com
VIN: License Plate:
6C BB BC
Revision: 53H22000
Revision: 00H06V07
Coding: 0014
Coding: 030C0C
Coding: 0A47F7
Coding: 00006C
Light switch:
Alarm horn:
Sun Roof:
Coding: 101F00
Coding: 0470151011
Coding: 333135
Coding: 333135
Occupant Detection:
Coding: 303337
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2018
Alternator:
Coding: 0601
Revision: --------
Coding: 04C002
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 84
Mileage: 3498 km
Date: 2017.11.20
Time: 16:35:50
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 84
Mileage: 3498 km
Date: 2017.11.20
Time: 16:35:50
1192264 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 84
Mileage: 3498 km
Date: 2017.11.20
Time: 16:35:50
Coding: 8106
Data medium:
Looks like Audi did not SVM (software version management) your car correctly, if at all. Two options:
1) If using VCDS and you don't have Lane Assist, go in to 19 - CAN Gateway > Installation List > untick 3C - Lane Change.
2) I can correctly SVM your vehicle back to factory settings.
Reactions: T-800
Thanks Again for the help. When I untick 3C. I get a lot more errors. I do have blindspot detection which I thought was part of the 3C settings but at this point I don't know. I did try to untick 3c in both obdeleven and in vagcom. maybe I am doing it wrong but it seems to create more issues when I remove that from the gateway. I can untick it and then provide a log. Again really appreciate the help.
Looks like you have some dependencies on the 3C module then. Car needs to go back to Audi for them to actually SVM it this time, if not then I have the tools to do it... otherwise you will need to pick apart all the coding until you have corrected the errors.
Reactions: T-800
Thanks. Dealer keeps thinking it’s a faulty sensor. Hopefully they can listen and just do what you have suggested. How hard
Is it to send me the svm and for me to get things back to normal?
The SVM process requires the use of the factory / dealership diagnostic tool, and an authorised online account with VW Group.
Sorry for the stupid question. Appreciate your help hopefully the dealer will be able to revert things back to normal. thanks again for helping me figure this out.
No such thing as a stupid question :)
Tell your dealer that you need an SVM comparison completing. Should be able to do the whole car and return it to stock within 45mins.
If you go through the history it shows you ever change you ever made. I would go through and make sure everything you did you then undid.
I did try this. Wasn't able to correct the issue. It appears that something changed the coding for module 3c and it won't allow me to change it back. It keeps looking for a different module. Hopefully the dealer can put it back. I did tell them about what @DJAlix said. Hopefully they listen.
Reactions: DJAlix
Interesting update.. Dealer just called me. Said that they are not able to resolve the issue so they ordered a new Module. Saying it needs to be replaced. the sensors will no longer hold calibration. Will be weeks before they can obtain the correct part from Germany.. :facepalm:
Might well be the case. Software Version Management would have returned any default / factory configurations but anything that would need calibrating would need doing over again. Bit of a coincidence that a sensor or control module has gone faulty, but then this is why I love OBDeleven... gives me lost of customers :)
Reactions: AudiNutta
Is it possible to make a change in obdeleven that would blow up the module? Seems like this should just be able to be reset back to what it was. I don't have a lot of confidence that the dealer replacing the module is going to correct the issue.
I would not go as far as blow up but cause damage or render useless 100% yes, and I have seen this. The Coding and Adaptation side of things is not so much of a problem as you have manual control over whats going on. Unless there is a bug in that side of things then the only issue could be the user making a change that they shouldn't, like changing a voltage setting etc. The main problem is the "apps" side. This is an automated process in which you have to put your trust in the developer. Some codings and adaptations will effect the status of stored calibration data also, so changing one thing may "unlearn" data which is needed in order for a feature to work correctly, and might need calibration equipment like the following:
Lane assist calibration:
20160107 164645
Reversing Camera Calibration:
HGS Rear Cam Kit 800x567
Some changes, like video in motion, are made via editing the control modules firmware and this can be very very dangerous.
825
D0C
10
24
