Hi folks,
I have a B7 Sline, 140 Tdi multitronic, 68k miles on the clock and with a BRE engine (not sure whether to smile or cry). I started getting this strange sound back in August and ran a scan twice. Both times no faults found with the most recent scan being yesterday.
I am not sure what this sound is (not experienced enough to identify or relate it to a specific part). Below are the "symptoms":
1- It only happens when the engine is warm and running for sometime.
2- It doesn't happen every time you start the car even if the engine is warm.
3- Sometimes it would crank but start (like in the video)
4- Other times, it won't start making the same noice (as in the video).
5- Sometimes when it starts it leaves smoke (believe it is black)
6- You turn off the ignition and re-start and no noise, at all. It would appear the problem doesn't even exist.
6- There is no engine sound at all whether the car is idle or running. This happens only while starting the car.
7- It doesn't happen when the engine is cold or you start first thing in the morning.
8- It is not weather dependent as it is happening these days. Not that it is snowing outside but ...
I tried 8-10 times just to record the attached video and it happened only 3 times. Rest was absolutely fine. I know sometimes it is really difficult to identify the root cause from the video but any help/pointers would be highly appreciated.
