U.K 2010 S5 Convertible Rear Led VCDS Coding
rookie
Hi all,
As you may or not be aware I just had my comfort control module changed after my previous one failed. I got the car back yesterday and all appeared well. However when I locked the car today I noticed the amber rear indicators did not flash, instead it was a red light that illuminated (on the outer cluster inside the led section). I also noticed the rear fog lights didn't work (the switch light flashed on, but turned off after a second).
I put this down to a coding issue, and using VCDS I checked the following channels in module 46: Central Convenience
181 - 65535
189 - 16383
191 - 16143
195 - 14852
196 - 14884
197 - 14980
198 - 15012
203 - 8266
204 - 82998
I understand these codings are for the standard halogen? I found a guide that recommended the following changed to code a halogen unit to a pre-facelift led that recommended the following changes
181 - 65535 to 64608
189 - 16383 to 16380
191 - 16143 to 16383
195 - 14852 to 5125
196 - 14884 to 5157
197 - 14980 to 5124
198 - 15012 to 5156
203 - 8266 to 73
204 - 8298 to 105
However I understand these instructions are for people using a Kufatec loom for a halogen to led retrofit and are possibly for a coupe. I really need the standard VCDS coding for a 2010 convertible pre-facelift rear LED unit; does anybody have these, or know where I can get them?
If not, are there any pre-facelift convertible owners that have VCDS that could do me a HUGE favour and check the values in the following channels in module 46 - adaptation (you'll need enter the security access login prior to entering the adaptation section, the codes are 41067 or 16017 - 16017 worked for me).
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
I realise this is a big ask and it will take a few minutes, but it would really help!! I beleive channels 207 and 208 relate to the indicators, but I'd like to check all the codes to be sure!
So I finally managed to get this resolved. I tried the many suggestions given to me on various forums, but unfortunately none of them worked. I finally came across a post where somebody posted up the coding for Sportback with pre-facelift LEDs (they use the same units). I tried this coding and it worked! So for anybody else that has the same issue with factory fit pre-facelift LEDs the coding required is as follows
185:65535
195:5124
196:5156
197:5251
198:5283
199:12
200:44
201:133
202:165
203:73
204:105
205:13
206:45
207:5
208:37
209:0
210:0
