Having owned a B5 before I understand the limitations of the front speakers and fitting new ones.
In my old B5, I upgraded the fronts to a set of Pioneer 130cm components using the autoleads adaptors.
I noticed no difference using the standard Concert radio and was unimpressed with the sound even after changing the head unit. No bass and lots of rattles.
Clearly the car depends on the rears for the bass.
What results has anyone had by amping the standard speakers, front and/or rear using a proper amp? Either with the original radio or with a new head unit.
I'm aware the concert radio does have a pre-out option which I think will bypass the built in Audi EQ and bass reduction at volume? Does it sound any good when connected to an external amp? I suspect probably not!
I've never heard the Bose option. Is it that much better?
If I keep the Concert I will use the CD changer input as an aux in and mostly use my phone to play Spotify through it.
Stu.
Stu.
