Hey, check the link in the last post here.Hi, could you share the link for the Bluetooth adapter? I have the same head unit as you, would love Bluetooth.
I already have a Sachs Performance clutch with an LUK DMF.
Stg2+ it is then...
I installed the same one. At first I thought it would bother me, disturbing the aesthetics of the dash & vents. I had been using a mount on the coin tray, which worked OK, but would end up a problem when switching from single to double-DIN. But I have gotten used to it. The convenience is well worth it!Installed a phone mount from oem-mounts!
And installed a Bluetooth adapter for both voice and streaming from eBay.
Both perfect. Very pleased!
Well, I was wrong. The VCDS coding change was for "Cold Diagnosis." This is only when the car electrics are initially activated. But then when you go to use the turn signal while the car is running, the bulb out warning is triggered. I spent about an hour searching around... and it seems there's no control panel option to turn that off. I don't understand why not... but that's chaos for you, attempting to foil the plans of mice & men.
Dynamic indicators fitted in the wing mirrors, they look great, got bumper off and stripped ready for the new one to be painted and built back up
Any pics or links?
I got a pair for the rear turn signals that work great with no bulb-out warnings. I don't know if it's something to do with overall drain on the circuit, though. The rears may draw just enough to keep the load above the threshold, but the side indicators put it below.Indicators typically don’t like LED bulbs. Very hard to find one that works.
Can you send me a link to those dynamic indicatir strugling to find a realiable setDynamic indicators fitted in the wing mirrors, they look great, got bumper off and stripped ready for the new one to be painted and built back up
Sent from my SM-N976B using Tapatalk
Hows the installation?There you go mate, from aliexpress, took about 2 weeks to come but could’ve been worse!
£28.14 63% Off | KIBOWEAR Dynamic Blinker Mirror Light for Audi A3 8P A4 A5 B8 Q3 A6 C6 4F S6 LED Turn Signal Side Indicator S4 S5 S6 A8 D3 8K S8
https://s.click.aliexpress.com/e/KYg0nMWM
Very easy, just need plastic removal tools to get the glass and bottom mirror housing off, few little torque screws out and just plug and go. Less than 20 minutes start to finish
Can you still see the indicator working on the inside of the housing? So when you're driving with the indicator on you can see it flashing. Read reviews saying it doesn't but they weren't really descriptive
They have one for the older A4 B8.5 mirror looks like it could be compatible with the 8P mirror design from 2006~2008 years (not 2008~2013). https://www.aliexpress.com/item/32908613197.html?spm=a2g0o.detail.1000023.10.739b6629kiKU0s Since the A3 8P from 2006~2008 years wasn't wired for turn signals in mirrors, this would have to be wired in series to a lead from a signal wire threaded from the cabin. I wonder if it might be possible to run a lead from the fender signal wire.There you go mate, from aliexpress, took about 2 weeks to come but could’ve been worse!
The bulbs are Auxito. They have a number of different designs. This particular one worked (153621017575), but I didn't have any other LED's in the circuit.Any links?
Not taken any pics cause it just looks like a half working indicator lol, not sure how to post videos either
https://s.click.aliexpress.com/e/tEGcuuik
That’s where I got them, good fit, work in time with the on&off glow from the headlight indicator aswell, very happy!
Cheers. Been waiting for the price to drop on these since I saw them around the 40 quid mark.
At 28 it's a great deal might wait a bit longer though. Such a pointless mod but one I'm drawn to and will most likely end up doing all the same
thanks, yeah its that square bit on the edge of the inside i was on aboutSo these don’t show you when the indicator is still on from the little square bit like they do with standard ones, but the indicator itself is brighter than normal and doesn’t seem to have much blocking the light coming from behind the mirror glass.
Main reason I changed them to dynamic ones is that my passenger side indicator had died, new genuine Audi ones are £30+ and these were £28 for the pair. Even at the same price I would keep the dynamic ones, they look great to me
'tis the season.
Nobody wants to feel a cold knob in the morning haha.It’s f**king November
The + part of any map is the fuel pump upgrade and it adds lots of torque which you feel as acceleration. Go on change your mind!!Decided against uprated HPFP internals and RS4 return valve, booked in for a Stage 2 remap complete with a cheeky ‘Black Friday’ deal, roll on the 29th.
I was not sure what is wrong with the car... As firs I was thinking that the comfort module is not working properly or the keys are defective. So I decide to order cheap key just to test... I ask in store kow much for 2 original keys they told me 300 euros with coding... Its too much for my standard right now.. I must byu new wheels with tires now it gonna be around 400 eu.. Too much but I must do that cuz winter is coming hehehe.. Nex I want to inspect is it possible to change headlights with xenon lights at all.. Complete with headlights bulbs traffo wires etc...Dont bother with the ali express illuminated puddle lights with a logo. Mine are 6 months old and the logo has faded away, just a white light now
