audi-a3-2s8
- Joined
- Feb 15, 2017
- Messages
- 5
- Reaction score
- 0
- Points
- 1
- Age
- 36
I went to start my Audi A3 and the car started up, then the dash went off and the car cut out. A friend of mine has VCDS and ran a scan, with the following results. Anybody had any similar problems?
Here's the VCDS read out
Wednesday,15,February,2017,19:00:19:40973
VCDS -- Windows Based VAG/VAS Emulator
Data version: 20130910
VIN: License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 63 73 76
VIN:
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Cannot be reached 1100
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
63-Entry Assist,D -- Status: Cannot be reached 1100
73-Entry Assist, P -- Status: Cannot be reached 1100
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
Component: R4 2.0l PPD1.2 4350
Revision: --H52--- Serial number: AUX7Z0H1FNI143
Coding: 0000072
Shop #: WSC 00029 210 72227
VCID: 74E73A52171B22BE80B-8021
2 Faults Found:
005712 - Powertrain Data Bus
P1650 - 009 - Missing Message from Instrument Cluster
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 17
Reset counter: 40
Mileage: 155242 km
Time Indication: 0
Date: 2017.02.15
Time: 18:29:24
Freeze Frame:
RPM: 768 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 12.20 V
Bin. Bits: 11100100
Torque: 1016.0 Nm
005488 - Engine Start Blocked by Immobilizer
P1570 - 008 -
Freeze Frame:
Fault Status: 11101000
Fault Priority: 4
Fault Frequency: 3
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 1888 /min
Torque: 152.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 12.09 V
Bin. Bits: 00111001
Bin. Bits: 00000000
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 73E5394E12152586991-8026
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication
00474 - Control Module for Immobilizer
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
Component: KlimavollautomatH19 0430
Revision: 133207 Serial number: 8P0820043AH
Shop #: WSC 00000 000 00000
VCID: 72EB3C4A6D0F2C8E927-8027
2 Faults Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 175
Mileage: 154674 km
Time Indication: 0
Date: 2017.02.10
Time: 18:20:34
Freeze Frame:
Temperature: 2.0°C
Voltage: 14.50 V
RPM: 2200 /min
Load: 0.0 %
Load: 9.0 %
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 152
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000008064223
Coding: F58A1F07A01410004F0000000000000000084E175A050000000000000000
Shop #: WSC 06314 000 08192
VCID: 4581B7960C01EB36E75-8010
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00150573
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 N HW: 8P0 959 655 N
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CR0014TLB
Coding: 0071612
VCID: 4D918FB6D47113762F5-8018
Subsystem 1 - Serial number: 63328RB4038924015
Subsystem 2 - Serial number: 63428RB403855A98R
Subsystem 3 - Serial number: 63528RB4038921A6J
Subsystem 4 - Serial number: 63628RB403855A1DQ
Subsystem 5 - Serial number: 63747RB40369E282R
Subsystem 6 - Serial number: 63847RB40369E2A8-
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 152
Mileage: 0 km
Time Indication: 0
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002012
VCID: 4189A3861829C716DBD-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 981 K HW: 8P0 920 981 K
Component: KOMBIINSTR. VDO H22 0660
Revision: D0H22003 Serial number: 2241H003110021
Shop #: WSC 00000 011 2053004
VCID: 408FA6821323CE1ED43-8015
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0192
Revision: H16 Serial number: 2500K08218012F
Coding: E9811F0E1C02020101
VCID: 3467FA52579B62BE40B-8061
6 Faults Found:
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 152
Time Indication: 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Time Indication: 15
02010 - Left Entry Assistance Control Module (J572)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Time Indication: 15
02011 - Right Entry Assistance Control Module (J573)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Time Indication: 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Time Indication: 15
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Time Indication: 15
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H03 0050
Coding: 0004728
VCID: 428BAC8A1D2FDC0EC27-8017
No fault code found.
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
Shop #: WSC 02069 000 90108
VCID: 3663C05A41E770AE7EF-8063
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1880202002586D29850548DAC637
VCID: 4385A98E0235D506C91-8016
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
Coding: 0004728
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000012
VCID: 3F8DA57E6EDDB1E6AD9-806A
1 Fault Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 8 km
Time Indication: 0
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H02 0270
Revision: 00H02000 Serial number: AUZ1Z3H8885213
Coding: 0330201
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 152
Mileage: 0 km
Time Indication: 0
Address 63: Entry Assist,D
Cannot be reached
Address 73: Entry Assist, P
Cannot be reached
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0070
Revision: 00H09000 Serial number: 00067824840804
Coding: 0000113
Shop #: WSC 131071 1023 2097151
VCID: 3C77D2727FCBAAFE88B-8069
End ---------------------------------------------------------------------
VIN: License Plate:
VIN:
Coding: 0000072
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 17
Reset counter: 40
Mileage: 155242 km
Time Indication: 0
Date: 2017.02.15
Time: 18:29:24
Freeze Frame:
RPM: 768 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 12.20 V
Bin. Bits: 11100100
Torque: 1016.0 Nm
P1570 - 008 -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 1888 /min
Torque: 152.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 12.09 V
Bin. Bits: 00111001
Bin. Bits: 00000000
Readiness: N/A
Revision: 00H11001
Coding: 0023170
2 Faults Found:
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 175
Mileage: 154674 km
Time Indication: 0
Date: 2017.02.10
Time: 18:20:34
Freeze Frame:
Temperature: 2.0°C
Voltage: 14.50 V
RPM: 2200 /min
Load: 0.0 %
Load: 9.0 %
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 152
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Coding: 00062736
Shop #: WSC 06314
Coding: 00150573
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
Coding: 0071612
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 152
Mileage: 0 km
Time Indication: 0
Coding: 0002012
1 Fault Found:
No Faults Found
6 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 152
Time Indication: 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Time Indication: 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Time Indication: 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Time Indication: 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Time Indication: 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Time Indication: 15
Cannot be reached
Coding: 0004728
Cannot be reached
Coding: 0004728
Coding: 0000012
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 8 km
Time Indication: 0
Coding: 0330201
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 152
Mileage: 0 km
Time Indication: 0
Cannot be reached
Cannot be reached
Coding: 0000113
