Oil type with EGR & DPF delete......
carlcall
Well-Known Member
55
Up North - Blackpool
Basically I appear to have had a slight brain fart and it's now dawned on me that in theory, I should now not be stuck to the VW 504 00 & 507 00 5W-30 specified oil as I no longer need the lower SAPS as I no longer have a DPF.
So I am right in thinking that I can now use an oil that no longer has to be to the above specs?
Sounds correct Carl , I may have some extra info shortly.
Rob
As Rob said, in theory you could swap. Any reason why though?
I would imagine the choice of oil brands and specs etc would increase a lot and thus pricing levels would also be very good.
I allways used castrol magnatec before and after when I had my dpf removed. Had no problems with it.
