Convert sport to standard suspension
calico
I have an A3 Quattro sportback with sports suspension which is far too hard and jiggly for UK roads. Is it possible to convert it to the non sports suspension, which of course I should have selected when I bought the car.
Yes, springs and dampers need changing then suspension alignment at your chosen tyre dealer.
Do you have sport or S-Line?
You will probably pick up some 2nd hand springs and dampers on ebay or here for next to nothing.
Fitting is £45 hour roughly and book time 3.7 hours, maybe less if the dampers are already fixed to springs, but make sure thats with alignment and preferably hunter alignment.
You might like to think about changing just the springs if you have the S-Line for Eibach Pro springs, lots of discussions about it on here at the moment.
I'm changing mine on my S-Line in the next few weeks, and thats because of the horrible crashy ride you get with the standard S-Line springs.
Arrange a swap ?
Go down a rim size (larger sidewall on replacement tyre, less air pressure needed. (To a point))
Reactions: SootySport
