Looks excellent Alex, glad you're happy with them, so much better than the oem ones.
They are a bit more expensive than other tips but the quality is first rate and the seller provided a very good service.
Looks much better Alex did you say they was 89mm tips? And what inner size did you go for?
Ok thank you mate think I've found some i like but my exhaust guy is full booked for the next 3 weeks ahhh i just want some noise now lol I'm caught in two minds to go 89mm or 101mm tip.They are 89mm exit with a 60 and 50mm od reducer, the pipe exiting the stock bach boxes are 50mm so i straight but up joint and weld.
Yeah if you could do that would be great, I've seen a few with the 4” and when they look awesome but only if they have been fitted flush but yours looks really good so its out me in two minds now...I could pm you some more detailed pics for 90mm reference if your looking for some more inspiration
They sit in a bit to much for me Rob i like them so there flush and fit like there part of the rear splitter as much as possible.
Could be the lighting maybe who knows! Due to the shape of the valence and the straight edge of the tips i went for a 50/50 fitment when looking from above, half is visible the other half is beneath the valence.
Too far in makes them look naff and smaller and defeats the object of having nice shiny bits. Too far out however makes you look like you packing some heavy chav cannon artillery!
Yep that’s the ones... I do like the black Cherokee tips though, might have a change shortlyAre those those milltek 100mm jet tips Rob.
Nearly all the other sections have one of these threads and I can't find one on our section so thought I'd start us off.
Over the last few days I've done
New gear knob
New dv
New pcv valve
New pcv gasket
New n80
Cleaned TB and new gasket
New rear brakes
Painted all brake calipers and dust guards.
New pollen filter.
So what you lot been upto?
Where is DV so I want to check itNearly all the other sections have one of these threads and I can't find one on our section so thought I'd start us off.
New gear knob
New dv
New pcv valve
New pcv gasket
New n80
New rear brakes
New pollen filter.
Yeah definitely a big fan of the 100mm cant wait to get mine in now...roll on 3rd August
They look the business! did you weld or clamp?They are 89mm exit with a 60 and 50mm od reducer, the pipe exiting the stock bach boxes are 50mm so i straight but up joint and weld.
Now where's my hoodie...Welded them on, 100% control over fitment and they wont be stolen by a hooded scrote!
Hoodies are sooo 90’s you need to go full lion king facepaint its the way forward mate, plus theres no evidence of clothing, just baby wipe it off
LolI better stop collecting those old stockings in that case!
