Can I disable the One-Touch Windows?
RicB
I guess I'm old-school, but I hate the one-touch feature and want to disable it. Can that be done? I have a 2011 US 2.0T. Thanks.
I think you may be able to in the same way I reset mine, try holding the up button for a few seconds when they are fully up
You can disable automatic run on the door modules yes, vcds coding.
The switches are 2-stage switches, so you can "half-press", its less faff than disabling them, and does the same job :)
If you disconnect your battery I'm sure it will need resetting after this, just don't reset the one touch and then your sorted
It does this on mine but mines a 2006 so yours may not be the same, worth a shot though
Reactions: TimWills28
