Rear armrest removal
Ali2.0tfsi
Hi guys manage to find a rear armrest with cup holders as my car don't have cup holder in the back.
Anyone know how to remove the rear arm rest so I can just fit new one in.
Is it a easy job?
Thanks in advance
Is it a easy job?
Thanks in advance
Removing and installing centre armrest (split backrest)
A74 0175
1 - Centre armrest
t Removing
– Fold down centre armrest -1-.
– Pull off hinge trim (outside) -2- in direction of -arrow-.
– Unscrew bolts -3-.
– Release pin -4- from hinge arm -5-.
– Detach centre armrest -1-.
t Installing
Install in reverse order of removal.
2 - Hinge trim (outside)
3 - Bolt
4 - Pin
5 - Hinge arm
A74 0175
Removing mounting bush
– Use flat screwdriver to press off mounting bush -1- in direction of -arrow-.
2 - Backrest cover
Also this may help.
Reactions: Ali2.0tfsi
What's up with your old one?
If it's the catch, Audi do a repair kit that includes the catch for about £25-30
The base part number is 8F0898173,repair set; armrest (upper part)
You need to go via Audi for the dash number as it is related to your trim.
(It contains the lower plate too - just the cushion is not there)
Took about 10 mins to fit!
Nothi
nothing wrong with old one just wanted to fit one with cup holders that's all
Sorry, second picture should be.
2 - Backrest cover
A72 0265
[/QUOTE]
