Xenon level...
WayneCS3
33
So I recently changed my bulbs to 6000k as my oem ones were just to dull. when i turn on the car and the self levellers start to adjust they drop down then go back up .. ill admit they do seem too high when driving in the dark. is it a sign of the levellers screwing up? and would changing bulbs make them go?.
any info is appreciated.
I did the same exercise recently and checked the beam height before and after.
There was no change and the self levellers were working properly.
You should be able to adjust the whole headlight unit to compensate though, if you have to.
fair enough i might just leave it then im not bothered about blinding people as long as i can see haha. pretty sure you were the one who pointed me to the d1s bulbs from hid-direct ..if it was .. cheers i have had bad bulbs from them but these ones seem great so far
Reactions: Jake 61
Good stuff.
I've had no probs so far and like I said, one of the other lads on here has had a few sets with no bother at all.
Compared to £60.00 each for a Phillips or Osram bulb, it was worth a punt.
Quick check on low beam.
From 20 feet back from a wall the cuttoff should drop at least 2" lower than up against the wall.
