Agu injectors
Nickagu8l
Hi all been offered a set Saab injectors to fit my agu but not sure if they will work with a k04. The injector part number is 0280155749 and they are red top ones. Will these work?
If the injectors are 3 inches long 76mm with 14mm oring top and bottom they will fit, need to be high impedence EV1 or EV6 for plug and play fitment.
0280155749 are 16 ohm, 347cc
Get the injectors that are for the tune you are getting done
Ideally the injectors you want will start with the part number 0280150, these are the older style short fat stubby injectors that apparently work better with AGU injector drivers.
0280155 injectors are the newer Ev6 style that are long and thin
Old style
versus
New style
