Flat Bottom Steering Retrofit Advice please - Part Numbers Inside
Lingo89
I have a 2004 8P2 A3 sportback. It does have cruise control, but is not MFSW. I intend to convert to the 8P3 S3 Multi Function Flat Bottom Steering. I've posted a picture of my current steering wheel below.
The part numbers of the current setup are:
STEERING WHEEL CONTROLLER: 8P0 953 549 A
AIRBAG CONTROLLER: 8P0 969 655 C
Can anyone please advise on what will be required for the DIY retrofit other than steering wheel and airbag? I don't know whether my airbag is single stage or dual stage and what I need to be looking for to make sure I don't have a dash that looks like Christmas tree lights.
2004 is single stage air bag iirc
Wiring a single to a dual, you won't find anyone to help i bet due to the air bag
Lee are you sure? I have been told by others that this is the case with 3 doors, but mine is a sportback and that all sportbacks came with dual stage airbags. Does anyone know if there is a way to check this using the part numbers? (forgive me if this is blindingly obvious)...
Also realised I made a typo in the first post which I can't edit, the airbag controller number is actually:
AIRBAG CONTROLLER: 8P0 959 655 C
Yeah pretty sure, hopefully someone will confirm or deny :)
I'm pretty confused at this point as I'm getting conflicting information.
So I tried to check my part number for the Steering Control Module against the Rosstech website and found this which is pretty useful:
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Only issue I have is that my Steering Control Module isn't on the list unless 8P0 and 1K0 are the same thing?
My part number for the SCM is: 8P0 953 549 A, the part number that is extremely similar on the Rosstech site is: 1K0 953 549 A
If this is the case, my SCM is apparently midline, would this be good enough or does it need to be highline?
As always, all advice is much appreciated!
571
572
13
NHN
