What is this (broken) pipe for?
RickkyP
So I'm in the middle of fitting my replacement coil pack harness. (a job I'm not enjoying at all!)
And when I opened the wiring duct, I spotted this broken pipe: (just under the connector)
Before I glue it back together does anyone know what it is?
Cheers!
Thats the pipe/feed for your rear windscreen washer jet mate. Common issue with these coming apart. Nothing a bit of gaffa tape won't fix!
Brilliant! One of my next jobs was find out why the rear washer didn't work. Should save me time.
Reactions: Lodhiz and xpoweruk
It'll probably pop apart at the join in the boot after you fix that one; mine did :(
My actual washer jet motor was broken internally so it kept on leaking, even after replacing the pipe that joins to it with a silicon pipe. I even tried to be cheeky, and use sealant around the area it was leaking (I was desperate) but to no avail! These things are a right pain!
Any idea on price Alex? I'm in two minds about whether I should go down the wiper delete route (looks better) or to actually repair it.
mines leaking as well but to be honest I haven't noticed when I use the washers so I've left it lol
PN: 8L0998711
£37.5 ex VAT
Cheers, thanks for that Alex. Kit is comparable in price to buying a used motor jet, which may be a better option.
How is the pressure on your jets? Do you find them a bit weak? (mine are so weak i'd be better off blowing water through a straw). Just be mindful of the leaking water as that can leak into the boot catch switch (although you probably already know).
539
10
740
670
RGL
