H
HansfishS3
Guest
Hi all,
Was playing about with my Navi system and climate control today....put everything back together...noticed that the climate control fuse had blown :/ Now when I attempt to start the car nothing happens...it doesnt even crank. The Navi system acts as if it has no power coming to it....the DIS is displaying a yellow battery symbol....
When I attempt to start the car all power goes off an nothing happens....ran a Vagcom and got the following...any ideas?
EDIT: I should mention that the car seems to take a while to crank before today....
VCDS-Lite Version: Release 1.2
Saturday, 28 March 2015, 16:06:16:0
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
Address 01: Engine Labels: Redir Fail!
Controller: 8N0 906 018 J
Component: 1.8L R4/5VT 0004
Coding: 10710
Shop #: WSC 01236
VCID: 3803ABE30B4B
WAUZZZ8LZ11000405 AUZ7Z0A1825216
2 Faults Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
18011 - Internal Control Module: Failed Self-Test
P1603 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: None
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 01236
VCID: 3E0FBDFB296F
No fault code found.
Address 15: Airbags Labels: 8L0-959-655-AI8.LBL
Controller: 8L0 959 655 K
Component: Airbag Front+Kopf 5008
Coding: 01304
Shop #: WSC 01236
VCID: 46FFD51B71BF
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8L0-920-xxx-17.LBL
Controller: 8L0 920 980 L
Component: AB-KOMBIINSTR. VDO D12
Coding: 01444
Shop #: WSC 00001
VCID: 3C0BB7F33F73
5 Faults Found:
00667 - Ambient Temperature Signal
30-10 - Open or Short to Plus - Intermittent
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
01176 - Key
01300 - Control Module for Navigation with CD-Rom (J401)
49-10 - No Communications - Intermittent
01304 - Radio
Address 22: AWD Labels: 02D-900-554.LBL
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F31607F8EA5
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D16
Coding: 13163
Shop #: WSC 00149
VCID: EAA7C1AB8567
Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
VCID: E0B3A383735B
Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00014
Shop #: WSC 01236
VCID: E5BDB2976C79
Address 57: TV Tuner Labels: None
Controller: 4D0 919 146 B
Component: TV Tuner H05 0704
Coding: 0000010
Shop #: WSC 00000
VCID: 28237BA3DBEB
1 Fault Found:
00861 - Connection to Navigation Computer
011 - Open Circuit - Intermittent
End --------------------------------------------------------------------------------------------------
Coding: 10710
Shop #: WSC 01236
VCID: 3803ABE30B4B
2 Faults Found:
P0571 - 35-00 - -
Coding: 18448
Shop #: WSC 01236
VCID: 3E0FBDFB296F
Coding: 01304
Shop #: WSC 01236
VCID: 46FFD51B71BF
1 Fault Found:
Coding: 01444
Shop #: WSC 00001
VCID: 3C0BB7F33F73
5 Faults Found:
01176 - Key
01304 - Radio
VCID: 1F31607F8EA5
Coding: 13163
Shop #: WSC 00149
VCID: EAA7C1AB8567
Coding: 00001
Shop #: WSC 00000
VCID: E0B3A383735B
Coding: 00014
Shop #: WSC 01236
VCID: E5BDB2976C79
Coding: 0000010
Shop #: WSC 00000
VCID: 28237BA3DBEB
1 Fault Found:
