I'm wanting to sort out my sloppy gear shifter, replace bushes, adjust and generally improve on what I have. It was only 2 months ago that the plastic carrier/ shifter on my 5speed 1.8l box decided it'd had enough, and so I replaced it and adjusted the linkage. I'm now having to adjust it again and 1st and 2nd gear are becoming difficult to engage.
I've had a good look through past threads and found some useful advice on short shifters which is something I'm interested in. to be fair, the throw on the standard linkage is a bit excessive.
my concern is that most comments directed me towards a DieselGeek 5 Speed MK4 shifter. having looked at a quick video and understanding the requirements, Its not the same mechanism as whats on my box.
In the below link there are 3 different linkages discussed. I have the 1st. MK3?? (what I guessed was a Golf reference, expecting it to be MK4)
http://www.myturbodiesel.com/wiki/how-to-adjust-your-vw-and-audi-manual-shifter-cables/
Looking at the differences, but also taking into account that the Short shifter Kit requires the removal of the OEM linkage arms/ joints, Its looking possible that the MK3 is compatible with the MK4 hardware. can anybody confirm this?
Are there other short Shifters that come highly recommended by anyone here with the same setup as I have linkage-wise.
lastly. Im getting the impression that Front/Back movement is shortened by a lever design change (inside the car), and Left/Right is altered at the gearbox with a change of bracket/lever. there is no single piece that can be installed to shorten both movements.
(p.s. I found that the MK3 linkage has no locking device for adjustment)
