Hi all
I am looking for some opinions from those who have experienced issues with their clutch over the years, or who just know what they are talking about, unlike myself..
I have an A3 8P 2004 model with 150k on the clock. I bought this with 45k on the clock in 2007 so as far as I am aware, its never had anything done to the clutch.
Over the past year, starting back in around Feb 2014, I started to experience issues with the clutch. The issues went away as the weather went warmer although that maybe just a coincidence, but they have come back from November 2014 and are ongoing.
The symtoms are:
Clutch pedal frequently feels like it is being sucked to the floor when pressed and I have to pull it back up with my foot and pump it a few times otherwise I am unable to change gear and have to coast for a while which I work the pedal. Sometimes it takes longer than others. This as you can imagine is quite annoying at junctions.
The clutch bite point is also extremely low towards the floor when I am having these issues.
Sometimes the clutch operates fine, decent bite point and easy gear changes, but then a few miles later it will start to be sucked in again as its pressed. Its worse when coming off the motorway and onto a slip road.
The clutch does not appear to be exhibiting the symptoms of slipping, revs dive if a I put the car in 5th at low speed etc.
Took the car into a garage the other week and typically it was working fine that day so I have had the brake/clutch fluid replaced as it was a cheap thing to try but no joy.
Before I take it back to the garage, I am looking for some opinions on if this sounds like a specific part of the clutch system or if I will just have to have the whole lot, clutch, slave, master, flywheel all replaced which I am sure will cost a lot of money for a car that is probably only worth £1500-£2000 now on trade in.
Any opinions would be welcome
Rick
The symtoms are:
Rick
