Looks like the only difference is that the B6 had a reverse light on both sides and the B7 only has a reverse light on the RHS, therefore you would need to fool the car. (I've attached the diagrams, note the B7 in the UK does not have a reverse light on the LHS)
Just check and make sure of any other differences on the wiring diagrams, I havent printed them off and checked line by line.
Ok calculating what size resistor you need, you put a multimeter in series of the reverse light and see what current the control unit passes through to check if a bulb is there. For example if you read
0.5 Amps
EXAMPLE Power calculation
Power = Volts x Amps
Power = 12 x
0.5
Power = 6 Watts
EXAMPLE Resistance calculation
Resistance = Voltage / Current
Resistance = 12 /
0.5
Resistance = 24 Ohms
You need to use the current value to measure in the calculation above, obviously test it all and make sure the resistor is not getting hot in service
P.S. The wiring diagrams also have the pin outs.
View attachment 49065 View attachment 49066 View attachment 49067 View attachment 49068
