engine coolant sensor
makster1978
hi can anybody tell me were the other end of loom joins to for the coolant temp sensor I have replaced the sensor and connecter looks ok but not sure were the other end connects to check it,error code keeps returning after It is cleared 16500,1.8t agu thanks
cheers m8 so no code for thermostat possible then? I will change it,am I right in thinking the sensor is joined to the fan module
It is quite a common fault and usually traced back to thermostat if its not the thermistor. I'm sorry but I cant tell you where the loom goes exactly as I've never had to trace it back
Steve
I had that code on mine. Cleared and came back. Changed the thermostat and the code hasnt come back :)
