Hi from west sussex.
GaryQuattro
Crawley
Hi All
I had my Audi A3 2.0 Tfsi for about two years now and have just retro fitted RNSe today works but I am going to need VCDS help as there's issues with 19 can gateway and 37 Navigation.
I have Vcds but only just got it so its a case of having the tool but no idea at the moment.
Gary
Hi Thanks for the link it was helpful.
I have got the Rnse wired / plugged in and working but have a fault code that I need help with ?
is there a problem with the rnse unit or coding issue any help would be appreciated.
fault in Address 56
this is the VCDS readings
Monday,08,December,2014,16:28:47:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 56 62 72
VIN: WAUZZZ8P57A008986 Mileage: 94850km/58937miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 K HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: --H14--- Serial number: AUX7Z0F4FNN0PM
Coding: 01030003180F0160
Shop #: WSC 00134 210 88439
VCID: 3A712C317544B89
No fault code found.
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021122
Shop #: WSC 06314 000 00000
VCID: 72E1C4116DB4009
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 Q HW: 8P0 820 043 Q
Component: KlimavollautomatH18 0300
Revision: 031457 Serial number: 8P0820043Q
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000005817504
Coding: E18C5F01B014100000160000160000000008FE175C0100
Shop #: WSC 06314 000 08192
VCID: 40855ED91398E29
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH12 0090
Coding: 00150573
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H12 3760
Revision: 91H12376 Serial number: 003620G0RR4%
Coding: 0071612
VCID: 428154D11D94F09
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0000042
VCID: 78F5F6390BC86A9
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 G HW: 8P0 920 981 G
Component: KOMBIINSTR. VDO H16 0550
Revision: D0H16001 Serial number: 2244F001000555
Coding: 0005413
Shop #: WSC 13889 001 1048576
VCID: 3C7D2A297F70869
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 G HW: 1K0 907 951
Component: J533__Gateway H10 0140
Revision: H10 Serial number: 30001065178B14
Coding: BD3F034807002103
VCID: 2B5F19758A1E111
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 F
Component: Haldex 4Motion 0115
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 30650E19A338729
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H16001 Serial number: AUX7Z0F4FNN0PM
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H99 0220
Revision: 0000013S Serial number: AUZBZ7P9900063
Coding: 0205153
Shop #: WSC 51924 001 10485
VCID: 346D020957204E9
1 Fault Found:
16353 - Control Module - Internal Malfunction
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 184
Mileage: 94845 km
Time Indication: 0
Date: 2014.12.08
Time: 15:19:06
Freeze Frame:
Bin. Bits: 01
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000688
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
Shop #: WSC 02069 000 90108
VCID: 356B3F0D5C5A571
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 198000186D088505489FC63300
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000688
VCID: 41835BDD1892EB1
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0205153
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 184
Mileage: 94859 km
Time Indication: 0
Date: 2014.12.08
Time: 16:05:53
Freeze Frame:
Bin. Bits: 01
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0070
Coding: 0000144
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000144
End ---------------------------------------------------------------------
thanks
Gary
Hi Gary, welcome to audi-sport.net. Hope you enjoy the forum. :) x
I have now sorted the faults codes malfunction codes after replacing the Symphony II with a Mk2 RNSe SatNav in my 2007 8P.
No quodlock block socket on original radio but ISO connectors so used an adaptor harness as plug and play with quodlock connector block.
Gary
Reactions: Sandra
602
342
K
501
