Down pipe come away from turbo
JasonS3quattro8L
Hi guys,
My down pipe has come away from the turbo, you can see the gasket hanging out and it looks like the bolts have snapped. My turbo was changed a few months ago and now this has happened. What size bolts do I need and am I right in thinking that I can get it back on by removing the charge pipe and the strut brace?
The standard turbo has studs and nuts rather than bolts as I found out the hard way. I ended up using bolts on mine as I discarded the old turbo before I realised. The top bolt can be reached by removing strut and charge pipe. Very tricky though. I used a couple of universal joints and a mirror. I also removed the O2 sensor. Other 2 are handiest through the wheel arch, and even easier with the drive shaft removed
I've heard about removing the driveshaft, sounds as if it's the easiest way and I like things that way. Hopefully I can get some new studs tomorrow as I really need my car back on the road for work Monday. I just don't get why it's come away, I can only come up with that the down pipe must of been under some tension.
38mm m8 studs with 1.5 pitch thread. I doubt very much they have snapped unless the downpipe isn't fitted correctly or the dog bone mount is knackered and its caused big twisting on the downpipe turbo..
36
4K
708
