Will try my best m8.Keep us updated with pics and details Mario. Il be doing mine next so will be good to see how you get on in case i get stuck and need to reference how you installed it.
Chess m8
My kit should be here the day after tomorrow!
Will be looking forward to do my install
Alex would love to hear your inputAlex do you think I should bolt the pump to the boot floor? Or just having it seated and secured in the black foam near the sore tire is sufficient?
Hi there....mine is bolted in place.
Alex, What are using as your Water meth mix?? 50/50 pre-mix or are you using screenwash??
Trying to research what is best, would quite like to run the 50/50 mix but i dont fancy paying around £35 posted for 5l of the pre mixed stuff and i feel as if the 30/70 mix in screenwash would be not as beneficial for the set-up i'm going to be running.
Where can i get Methanol cheapish and mix myself? Does anyone know if the water needs to be distilled or can I use tap water??
I got a RO treatment water filter under the sink. From googling around seems that I can normally use it to mix with methanol. What do you think?You can get pure methanol for way less than that.
My local model shop will do 5L of methanol for under £10,and Halfords sell demineralised water for around £5 for 5L.
Dont use tap water,esp in hard water areas,as the nozzle will eventually fur up.
What do you use Alex to top your system up??As long as it's deionised( as an RO filter should) then it should be fine.
Alex is it better to mix 10liters of methanol with 10 liters of water and store them in a 20 liter gallon?As long as it's deionised( as an RO filter should) then it should be fine.
Alex, took a trip in to Halfords at the weekend and could only find De-ionised water for £3.99 for 5 litres. Will this be safe to run??Pure methanol from my local model shop,plus Halfords demin water.
IIRC,10L of that mix amounts to about £14-15
just book marking this for my w/m setup in the new year. nice work mario and good luck with the rest of your install...
When I switch the system/gauge off the car doesn't boost at all. That's the failsafe feature .
You are correct guile I spoke too soonunless i've misunderstood your post mate i wouldn't call that a failsafe. i'm not trying to be smart, i just don't want you doing any damage to your engine...
for what its work i'm planning to install a solenoid to vent boost pressure from the wastegate on failsafe activation...
Thank you guilelooks like a neat install mate, well done...
Guys do you know anyone running the same system on the same car? Need to ask them a couple of questions
I hope so.
My switched 12v from the ECM has a 15 minute delay to switch off when I turn the ignition off. So now I have to switch the system off from the gauge whenever I leave the car.
Guess I can also just use my headlight switch too. As I already have my boost gauge taped into it.not the neatest of solutions but you could always wire it to the ignition so that when ever you turn your key back it cuts the power to the controller...
Does mixing water and methanol together lead to a warm mix?
Hahahahha I bet its a simple chemical reactionLatent heat of something but don't ask me what!
