Water inside car
Morne
51
Berkshire
Well today was washing the car opened passenger rear door,and found some mold took rear seat out and found some water just on the left side not all over.Put my hand up the seat rest where there is a wire and found that to be wet as well.So where would water come from?
Do you have a sunroof?
There should be drainage tubes running from four corners of the sunroof. Some of them go through the c pillar. If it gets clogged, your seats and rear floor gets wet.
Thanks where should i be looking hope i dont sound dumb thanks
If you google it there should be quite a lot of info about it.
Btw. You're not from barnsley by a chance?
Use nylon strimmer wire and boiling water to clear the tubes so-to-speak. Should run clear at the front hinges and the rear arches.
Thanks for that will have a go and c thanks again
Hi took rear bumper off and there is no drain pipes am I thick or were the instructions for different car
KINDLE CAMERA 1412249035000
Hi the pipe in pic is from the petrol filler cap ,and i found them thanks for all help
